LCN Rollershutter integration with HomeKit
Tags: #<Tag:0x00007f17385367a8> #<Tag:0x00007f17385366e0> #<Tag:0x00007f1738536618>
I am using the LCN Binding to control Rollershutters.
Now, I would like to control them via HomeKit on Apple.
With the following metadata configuration in OH3 UI
value: WindowCovering,WindowCovering.CurrentPosition,WindowCovering.TargetPosition,WindowCovering.PositionState
config: {}
I get the following error and nothing moves:
2021-02-23 15:05:40.403 [WARN ] [bhandler.AbstractLcnModuleSubHandler] - Unsupported command: LcnModuleRollershutterRelaySubHandler: PercentType
Any idea, how this can be configured?
is this item working without homekit labels? can you set them to specific percent, e.g. 50% open?
it could be that your rollershutters only supports UP/DOWN command but not the percentage position.
if this is the case, you would need to write a rule to translate % to UP/DOWN for specific duration.
please take a look in this discussions
https://community.openhab.org/t/re-solved-homekit-integration-pairing-problems-ios-10-11/101667/20?u=yfre
