I have installed LED strip lights in my sisters new kitchen and would like to control them wirelessly. There are 4 independent strands. 1 white, 1 blue on one side of the kitchen, 1 white, 1 blue on the other. There is no feasible or clean method to wire these 2 sets of lights, however, each side of the kitchen has an outlet to get power from. I am wanting to control the white and blue independently to include on/off and dimmer function.
Any help on where to start would be greatly appreciated.
I’m not sure if I will need anything like ardino, raspberry pi, or any open source stuff. I just want a master controller and wireless slave so the lights can be turned on and off and dimmed simultaneously.
What kind of protocol do you want to use? (ex. Z-Wave, ZigBee, Wifi, etc etc).
For Z-wave you can use the Fibaro RGBW dimmer. You can use the in/output mode en control each strip separately with just 1 dimmer.
That’s possible with de fibaro module. You can control each strip’s 12v separately. You’ll need 1 ac/dc connected to de fibaro module and strips (max 4) connected to the outputs (R/G/B/W) and change the parameter to input/output mode instead of rgbw mode.
