Legacy bindings for openHAB3, esp: ekey, FritzboxTR064 and mqqteventbus
As I’m playing around a bit with openHAB3 M1, I did come across some bindings, I’d like to use with OH3 also - and as the polling in Poll: Which OH1.x addons do you use? - #103 by Wikibear was something I missed, perhaps someone has an idea for the following I use:
I know, there’s some discussion around
  • serial
  • expire
  • http
  • gpio
is there a chance to use these with OH3?
and also: If there was a replacement or an useable Eventbus in OH3, I can setup a second openHAB2.x with access to the legacy bindings and just push the items to the main OH3… I know, I could use the REST API, but that’s just a pain in the a$%, if I had to write a rule on the legacy-items for use in OH3.
In case you weren’t aware: this issue tracks the status of existing bindings, and what will happen in v3
Have another look around for this. While there are grand plans for OH3, the OH2 version is useable under OH3.
Likewise, another look around
I do not think any ‘native’ solution is ready, however this is available now
for example: I saw, ekey was not voted on (but I do know, there are a bunch of users here in the forum besides me) and if it says “supported”, it’s worked on for OH3? that would be fabulous!
Thanks for the heads up!
@kai is working on a solution for that, I believe. Personally I am experimenting with moving to HABApp which can have similar functionality.
A native version of both Expire (part of core) and the Event Bus (will be a separate plugin) are in work for OH 3. I can’t say where they are in terms of implementation but I think there has been activity on both.
