Lennox iComfort Binding development
I’m currently in the process of development a binding for Lennox iComfort WiFi thermostat system (not new E30/S30).
I think I’ve reached the stage when I can share my work with the community and when I need Alpha testers.
My work including all source files and compiled jar available here:
GIT iComfort Binding
Jar can be simply copied to /usr/share/openhab2/addons (on Unix like systems where OpenHAB installed from installation source or corresponding folder on other systems). OpenHAB need to be restarted.
Few things to note:
It is not done yet and I’m actively working on it. Thermostat display Thing is planned and has no active channels at the moment. I don’t have access to multiple systems on the same account and multi zone setup and however it should work it is not tested, greatly appreciate if somebody can provide feedback on that.
During my own testing I use Paper UI to add things, manual configuration should work as well however not test yet.
Also note that technically this is my first Java, Eclipse and GIT project, I don’t consider myself a programmer, any constructive criticism is welcome.
As a foot note - I’ve re-used a lot of code from evohome and nest binding, plus some reverse engineering I’ve found over the net so all the credits goes to them and big thank you to evohome binding developers.
K.
I would be happy to test it, but I’m new to openHab and can’t find a way to install this.
I don’t see a jar file in the repository and have trouble when downloading it to my openhabian. I clone it and then try to make the jar file with mvn package.
[INFO] Scanning for projects…
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-resolvable parent POM for org.openhab.binding:org.openhab.binding.ic omfortwifi:[unknown-version]: Could not find artifact org.openhab.binding:pom:po m:2.5.0-SNAPSHOT and ‘parent.relativePath’ points at wrong local POM @ line 6, c olumn 11
[ERROR] The build could not read 1 project → [Help 1]
[ERROR]
[ERROR] The project org.openhab.binding:org.openhab.binding.icomfortwifi:[unkn own-version] (/home/openhabian/org.openhab.binding.icomfortwifi/pom.xml) has 1 e rror
[ERROR] Non-resolvable parent POM for org.openhab.binding:org.openhab.bindin g.icomfortwifi:[unknown-version]: Could not find artifact org.openhab.binding:po m:pom:2.5.0-SNAPSHOT and ‘parent.relativePath’ points at wrong local POM @ line 6, column 11 → [Help 2]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit ch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please rea d the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildin gException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/UnresolvableMo delException
Thank you for your interest!
JAR file is available on release page here:
Released JAR
I will fix Maven build later, for now I just use Eclipse to build it. Thanks for bring this to may attention.
Any feedback is welcome, not only bugs but functionality as well, at the moment I’m kind of at POC stage, however binding works fine for me.
Issue tracker
TA,
K.
Count me in for testing as well. I’ve had iComfort since 2013 and have been wanting to integrate since then. Seems Lennox is biding their time for an API. I’ll give you some feedback once they fix my remote login password.
Here’s the error log when I install the jar. I’m running 2.5.0.M1 :
2019-01-30 15:42:48.288 [ERROR] [org.openhab.binding.network ] - FrameworkEvent ERROR - org.openhab.binding.network
org.osgi.framework.ServiceException: Exception in org.apache.felix.scr.impl.manager.SingleComponentManager.getService()
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:222) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) ~[?:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:436) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:805) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:1) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:803) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:139) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:124) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:1) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:122) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction$23.run(SecureAction.java:474) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction$23.run(SecureAction.java:1) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:472) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:750) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:741) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:511) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:457) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:1001) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1382) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Caused by: java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/net/http/HttpClientFactory
at java.lang.Class.getDeclaredMethods0(Native Method) ~[?:?]
at java.lang.Class.privateGetDeclaredMethods(Class.java:2701) ~[?:?]
at java.lang.Class.getDeclaredMethods(Class.java:1975) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObjectAssignableMethod(BindMethod.java:469) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.doFindMethod(BindMethod.java:180) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.findMethod(BaseMethod.java:173) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$400(BaseMethod.java:41) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$NotResolved.resolve(BaseMethod.java:602) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$NotResolved.methodExists(BaseMethod.java:626) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.methodExists(BaseMethod.java:528) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:659) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1162) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1576) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1029) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:936) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:901) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
… 78 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.io.net.http.HttpClientFactory cannot be found by org.openhab.binding.network_2.5.0.qualifier
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
… 78 more
2019-01-30 15:42:48.443 [ERROR] [org.openhab.binding.network ] - FrameworkEvent ERROR - org.openhab.binding.network
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
… 69 more
… 69 more
2019-01-30 15:42:48.471 [ERROR] [org.openhab.binding.network ] - FrameworkEvent ERROR - org.openhab.binding.network
… 78 more
… 78 more
2019-01-30 15:42:48.512 [ERROR] [org.openhab.binding.network ] - FrameworkEvent ERROR - org.openhab.binding.network
Sorry, wrong file made its way to release page, fixed now. Thank you for your interest!
No joy:
2019-01-31 09:38:42.926 [ERROR] [org.openhab.binding.network ] - FrameworkEvent ERROR - org.openhab.binding.network
at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1919) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:459) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:390) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:302) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1242) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:997) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1176) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:927) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:892) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:135) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:969) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:823) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:805) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:584) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:716) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:511) ~[?:?]
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:428) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$300(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:291) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
at org.eclipse.osgi.container.Module.doStop(Module.java:634) ~[?:?]
at org.eclipse.osgi.container.Module.stop(Module.java:498) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.uninstall(ModuleContainer.java:399) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.uninstall(EquinoxBundle.java:446) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.uninstall(DirectoryWatcher.java:1098) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.uninstall(DirectoryWatcher.java:901) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:487) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) ~[?:?]
… 65 more
… 65 more
You are still using the wrong file:
I’m working on two bindings and somehow bad version the network one made it’s way to Git, both fixed since, you need to re-download and remove bad one.
iComfort Binding
If you want to test network one as well it is avail here (fixed one):
Network Binding
Reading it fine now. None of the controls enable write access though. Any troubleshooting ideas there?
This is by design, they supposed to be disabled in Away mode except away mode itself and enabled in Normal mode, this is to mimic Thermostat and web site behavior. Please let me know if that is not working properly!
Thanks, K.
The system is not in away mode so that’s not it. Do you recall the karaf command to enable trace mode on the debug? That may help find what’s different.
Here’s how to enable logging but I need to incorporate more logging into the binding itself.
Can you describe your scenario step by step possibly providing screenshots? I need to know what you mean by “Read-Only”. I’ll look on the code again and add more logging, would need that.
Thanks for testing!
Sorry for the delay. When I use the sitemap I can view items i’ve linked to the things (temperature, setpoints, humidity, etc.) but I can’t change them. That is what I meant by read only. Hope that helps.
I’ve added some additional logging (you need to set log level to debug).
Can you also provide your sitemap and try controls in Paper UI?
Thanks!
Installed new jar:
2019-02-14 18:07:49.740 [hingStatusInfoChangedEvent] - ‘icomfortwifi:account:iComfort’ changed from UNINITIALIZ
ED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-02-14 18:07:49.887 [hingStatusInfoChangedEvent] - ‘icomfortwifi:zone:iComfort:xxxxxxx760_0’ changed from U
NINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-02-14 18:07:49.888 [hingStatusInfoChangedEvent] - ‘icomfortwifi:thermostat:iComfort:xxxxxxx760’ changed fr
om UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-02-14 18:07:50.905 [hingStatusInfoChangedEvent] - ‘icomfortwifi:account:iComfort’ changed from INITIALIZIN
G to ONLINE
2019-02-14 18:07:50.933 [hingStatusInfoChangedEvent] - ‘icomfortwifi:thermostat:iComfort:xxxxxxx760’ changed fr
om UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-02-14 18:07:50.936 [hingStatusInfoChangedEvent] - ‘icomfortwifi:zone:iComfort:xxxxxxx760_0’ changed from U
2019-02-14 18:07:50.943 [hingStatusInfoChangedEvent] - ‘icomfortwifi:zone:iComfort:xxxxxxx760_0’ changed from I
NITIALIZING to ONLINE
2019-02-14 18:07:51.072 [hingStatusInfoChangedEvent] - ‘icomfortwifi:thermostat:iComfort:xxxxxxx760’ changed fr
om INITIALIZING to ONLINE
Karaf log level:
log:list
Logger │ Level
ROOT │ WARN
icomfort │ DEBUG
javax.jmdns │ ERROR
Sitemap:
sitemap hvac
Default item=Temperature
Default item=Humidity
Default item=Thermostat_Humidity
Default item=Thermostat_Temperature
Default item=Thermostat_Status
Default item=Thermostat_Mode
Default item=Thermostat_Away_Mode
Default item=Thermostat_Fan_Mode
Default item=Thermostat_Cool_Point
Default item=Thermostat_Heat_Point
Items:
Group gTemperature
Group gHumidity
Group gHVAC
Number Temperature “Temperature [%.0f °F]” {weather=“locationId=home, type=temperature, property=current, unit=fahrenheit”}
Number Humidity “Humidity [%d %%]” {weather=“locationId=home, type=atmosphere, property=humidity”}
Number Thermostat_Temperature “Hall Temp [%.0f °F]” (gTemperature) {channel=“icomfortwifi:zone:iComfort:xxxxxxx760_0:Temperature”}
Number:Dimensionless Thermostat_Humidity “Hall Humidity [%.0f %unit%]” (gHumidity) {channel=“icomfortwifi:zone:iComfort:xxxxxxx760_0:Humidity”}
String Thermostat_Status “System Status [%s]” (gHVAC) {channel=“icomfortwifi:zone:iComfort:xxxxxxx760_0:SystemStatus”}
String Thermostat_Mode “Operation Mode [%s]” (gHVAC) {channel=“icomfortwifi:zone:iComfort:xxxxxxx760_0:OperationMode”}
String Thermostat_Away_Mode “Away Mode [%s]” (gHVAC) {channel=“icomfortwifi:zone:demoaciComfortcount:xxxxxxx760_0:AwayMode”}
String Thermostat_Fan_Mode “Fan Mode [%s]” (gHVAC) {channel=“icomfortwifi:zone:iComfort:xxxxxxx760_0:FanMode”}
Number:Temperature Thermostat_Cool_Point “Cool Set Point [%.0f %unit%]” (gTemperature) {channel=“icomfortwifi:zone:iComfort:xxxxxxx760_0:CoolSetPoint”}
Number:Temperature Thermostat_Heat_Point “Heat Set Point [%.0f %unit%]” (gTemperature) {channel=“icomfortwifi:zone:iComfort:xxxxxxx760_0:HeatSetPoint”}
Tried changing fan mode to circulate in PaperUI:
2019-02-14 18:26:02.013 [ome.event.ItemCommandEvent] - Item ‘Thermostat_Fan_Mode’ received command CIRCULATE
  • 2019-02-14 18:26:02.017 [nt.ItemStatePredictedEvent] - Thermostat_Fan_Mode predicted to become CIRCULATE
2019-02-14 18:26:02.038 [vent.ItemStateChangedEvent] - Thermostat_Fan_Mode changed from AUTO to CIRCULATE
2019-02-14 18:26:02.337 [vent.ItemStateChangedEvent] - Thermostat_Cool_Point changed from 70.70 °F to 22.10 °F
2019-02-14 18:26:02.339 [vent.ItemStateChangedEvent] - Thermostat_Heat_Point changed from 66.20 °F to 19.40 °F
2019-02-14 18:26:28.621 [vent.ItemStateChangedEvent] - Temperature changed from 62.94 to 62.71
2019-02-14 18:26:28.623 [vent.ItemStateChangedEvent] - Humidity changed from 80.00 to 81.00
2019-02-14 18:26:55.989 [vent.ItemStateChangedEvent] - Thermostat_Fan_Mode changed from CIRCULATE to AUTO
2019-02-14 18:26:55.991 [vent.ItemStateChangedEvent] - Thermostat_Cool_Point changed from 22.10 °F to 70.70 °F
2019-02-14 18:26:55.992 [vent.ItemStateChangedEvent] - Thermostat_Heat_Point changed from 19.40 °F to 66.20 °F
  • 2019-02-14 18:28:03.767 [ome.event.ItemCommandEvent] - Item ‘Thermostat_Fan_Mode’ received command ON
2019-02-14 18:28:03.771 [nt.ItemStatePredictedEvent] - Thermostat_Fan_Mode predicted to become ON
2019-02-14 18:28:03.774 [vent.ItemStateChangedEvent] - Thermostat_Fan_Mode changed from AUTO to ON
2019-02-14 18:28:04.104 [vent.ItemStateChangedEvent] - Thermostat_Cool_Point changed from 70.70 °F to 22.10 °F
2019-02-14 18:28:04.109 [vent.ItemStateChangedEvent] - Thermostat_Heat_Point changed from 66.20 °F to 19.40 °F
2019-02-14 18:28:56.324 [vent.ItemStateChangedEvent] - Thermostat_Fan_Mode changed from ON to AUTO
2019-02-14 18:28:56.327 [vent.ItemStateChangedEvent] - Thermostat_Cool_Point changed from 22.10 °F to 70.70 °F
2019-02-14 18:28:56.329 [vent.ItemStateChangedEvent] - Thermostat_Heat_Point changed from 19.40 °F to 66.20 °F
2019-02-14 18:30:00.001 [vent.ChannelTriggeredEvent] - astro:sun:local:astroDusk#event triggered START
Seems there is a units issue for the set points? The changes made from PaperUI are being reset automatically. I made the changes marked with *. The other log entries appeared shortly afterwards (timestamps). I didn’t see any entries in the main log file, just the events log.
Yes, it seems like back end is not accepting settings in Fahrenheit, I assumed that it should work automatically but it seems like more to this. Let me have a look on the code.
Thanks for the log, it is very helpful!
I’ve made quick update for Imperial measurements, not ideal but should work for testing:
https://github.com/kpanchen/org.openhab.binding.icomfortwifi/releases/tag/2.5.0_c
Thanks!
Used PaperUI to change cool point. Looks like it took the change, then reported back in degrees C initially, then switched back to degrees F.
2019-02-22 13:57:06.485 [ome.event.ItemCommandEvent] - Item ‘Thermostat_Cool_Point’ received command 71 °F
2019-02-22 13:57:06.510 [nt.ItemStatePredictedEvent] - Thermostat_Cool_Point predicted to become 71 °F
2019-02-22 13:57:06.511 [vent.ItemStateChangedEvent] - Thermostat_Cool_Point changed from 69.80 °F to 71 °F
2019-02-22 13:57:06.843 [vent.ItemStateChangedEvent] - Thermostat_Cool_Point changed from 71 °F to 22.10 °F
2019-02-22 13:57:06.845 [vent.ItemStateChangedEvent] - Thermostat_Heat_Point changed from 66.20 °F to 19.40 °F
2019-02-22 13:58:04.815 [vent.ItemStateChangedEvent] - Thermostat_Cool_Point changed from 22.10 °F to 69.80 °F
2019-02-22 13:58:04.821 [vent.ItemStateChangedEvent] - Thermostat_Heat_Point changed from 19.40 °F to 66.20 °F
Away mode section doesn’t appear in PaperUI. No controls allows changes in BasicUI. Did my items definition look ok?
I know I still have that strange issue with temperature conversion, still working on it.
Away mode should appear in PaperUI, check that you have a channel link, works fine for me.
As for BasicUI - your things look fine, however in site map you used “Default” and they are all rendered as “Text”, you need to set them properly, here’s my example:
Frame label="iComfort" {
    Text item=Thermostat_Temperature
    Text item=Thermostat_Humudity
    Text item=Thermostat_Status
    Selection  item=Thermostat_Mode
    //mappings=[IDLE=System is idle", HEATING="System is heating", COOLING="System is cooling", WAITING="System is waiting", EMERGENCY_HEAT="System is emergency heating"]
    Switch item=Thermostat_Away_Mode mappings=[AWAY_ON="Away", AWAY_OFF="Not Away"]
    Selection  item=Thermostat_Fan_Mode mappings=[AUTO="Auto", ON="On", CIRCULATE="Circulate"]
    Setpoint item=Thermostat_Cool_Point
    Setpoint item=Thermostat_Heat_Point
I will update documentation with example later.
Thanks, let me know if you notice some other abnormalities, this is really helpful!!
I’ve made a lot of changes including to support Imperial unit system, from now on I get system from the back end, please have a look.
