I recently restarted my work on the the Lenox Icomfort WiFi binding. The binding is currently working in Openhab 5.2 and is available in my github repository in the Icomfort-WFi binding branch.
I am currently working on updating the binding to comply with Openhabs codeing and mark up guidelines.
This binding was based on the Nest and EVO Home bindings. Original code and development credits go to Konstantin Panchenko.
Note: This binding is compatible with older iComfort WiFi systems. It will not work with newer S30, E30, or M30 Smart Hub systems.
If you create a posing under bundles in the marketplace users will be able to install this add-on from the Add-on store instead of needing to download a jar file and drop in the addons folder.
Thanks so much for the suggestion! I did post (icomfort-wifi-binding) the 5.2 version as that is the one I originally built and tested the most in my test environment, but I also ended up making a second version of the jar for 5.1.1 for my prod instance of Openhab.
