Here is the response from the author of the original implementation
Yes, it would be possible to control devices. However, I had not coded this. I got as far as writing a method called sendCommand but I never finished the implementation.
Hi, I’m new to this and try to set up my air-conditioned to get per mqtt to openhab. I Have set up a raspberry, installed. I have installed Java 8 and Apache Maven 3.8.1.
I have done a git clone GitHub - mgwoj/Thinq-MQTT-Proxy followed by cd Thinq-MQTT-Proxy
Then copied the file with : cp state-example.json state.json
I have modified state.jason with my settings, but now what should i do?
Description says: java -jar ./target/thinq-mqtt-proxy.jar init
but I have no thinq-mqtt-proxy.jar where is it? where should i get it?
Yes i Installed Java and Maven (3.8.1 not 3.6.3)
The problem is probably the i could not do “mvn clean package”
It gives me this error:
[INFO] Scanning for projects…
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 0.463 s
[INFO] Finished at: 2021-04-16T20:23:16+02:00
[ERROR] The goal you specified requires a project to execute but there is no POM in this directory (/home/pi). Please verify you invoked Maven from the correct directory. → [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MissingProjectException
It looks that you have 4 devices, which is great. It means that communication with LQ servers works. Assuming that you have provided connection details for your local MQTT server (as described in the documentation), you should start receiving messages to your local topic, like thinq/washer/event/doorLock. You can use MQTT Explorer to check what is arriving.
Thats all right, i have 4 devices. I know MQTT Explorer and use it for other mqtt messages but i do not get anything from LG.
Am i doing something wrong in the json?
I have this:
This sound easier than it is. I was now editing on Raspberry Pi with nano. Tried to get all the stuff working on Windows but do not get it. Installing Eclipse on raspberry did also not work. I could give you access to my LG account for finding out the code if you would be so kind?
Or any hint how I could debug that easily :–)
It looks that your devices are in version 1 (V1). My recommendation is to remove them from your account and re-add using the LQ Thinq app. They should appear as V2 devices after this operation.
You can do this for one device at this moment to prove this approach.
Starting Thinq Mqtt Proxy...
Exception in thread "main" java.lang.ArrayIndexOutOfBoundsException: Index 1 out of bounds for length 1
at org.codehaus.groovy.runtime.dgmimpl.arrays.ObjectArrayGetAtMetaMethod.invoke(ObjectArrayGetAtMetaMethod.java:41)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:323)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.invoke(PojoMetaMethodSite.java:51)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:56)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:47)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:125)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:139)
at ThinQ_Integration.getOAuthDetailsFromUrl(ThinQ_Integration.groovy:628)
at ThinQ_Integration.prefDevices(ThinQ_Integration.groovy:251)
at ThinQ_Integration$prefDevices.call(Unknown Source)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:130)
at ThinqMqttProxy.doRun(ThinqMqttProxy.groovy:40)
at ThinqMqttProxy.main(ThinqMqttProxy.groovy:15)
