I have LG tv with Webos. I followed lgtv Webos binding & connected my TV with openhab2.
It works fine, but some time not working even if I can ping TV successfully.
Error in log is as below.
indent prefo
2019-02-04 19:39:00.009 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Power on TV via Wake on LAN’: The name ‘LG_TV0_WOL’ cannot be resolved to an item or type; line 6, column 18, length 10
Could you post your item definition file and your rule definition?
Hi
actually i followed documentation example as mentioned below.
Things file
Thing lgwebos:WebOSTV:tv1 [ deviceId="b52453f0-3d3c-4506-b16a-0d17304e5939" ]
Items file
Switch LG_TV0_Power "TV Power" <television> (GF_LivingRoom_TV,gLight ) ["Lighting"]{ autoupdate="false", channel="lgwebos:WebOSTV:tv1:power" }
Switch LG_TV0_Mute "TV Mute" <soundvolume_mute> (GF_LivingRoom_TV, gLight) ["Lighting"]{ channel="lgwebos:WebOSTV:tv1:mute"}
Dimmer LG_TV0_Volume "Volume [%S]" (GF_LivingRoom_TV, gLight) ["Lighting"]{ channel="lgwebos:WebOSTV:tv1:volume" }
Number LG_TV0_VolDummy "VolumeUpDown" /*(GF_LivingRoom_TV, gLight) */
Number LG_TV0_ChannelNo "Channel [%d]" (GF_LivingRoom_TV, gLight) ["Lighting"]{ channel="lgwebos:WebOSTV:tv1:channel" }
Number LG_TV0_ChannelDummy "ChannelUpDown" /*(GF_LivingRoom_TV, gLight)*/
String LG_TV0_Channel "Channel [%S]" (GF_LivingRoom_TV, gLight) ["Lighting"]{ channel="lgwebos:WebOSTV:tv1:channelName"}
String LG_TV0_Toast /*(GF_LivingRoom_TV, gLight)*/{ channel="lgwebos:WebOSTV:tv1:toast"}
Switch LG_TV0_Stop "Stop" (GF_LivingRoom_TV, gLight) ["Lighting"]{ autoupdate="true", channel="lgwebos:WebOSTV:tv1:mediaStop" }
String LG_TV0_Application "Application [%s]" /*(GF_LivingRoom_TV, gLight)*/{ channel="lgwebos:WebOSTV:tv1:appLauncher"}
Player LG_TV0_Player (GF_LivingRoom_TV, gLight){ channel="lgwebos:WebOSTV:tv1:mediaPlayer"}
Rules file
rule "Power on TV via Wake on LAN"
Item LG_TV0_Power received command ON
sendCommand( LG_TV0_WOL, ON)
// for relative volume changes
rule "VolumeUpDown"
when Item LG_TV0_VolDummy received command
switch receivedCommand{
case 0: LG_TV0_Volume.sendCommand(DECREASE)
case 1: LG_TV0_Volume.sendCommand(INCREASE)
// for relative channel changes
rule "ChannelUpDown"
when Item LG_TV0_ChannelDummy received command
var currentChannel = LG_TV0_ChannelNo.state as DecimalType
case 0: LG_TV0_ChannelNo.sendCommand(currentChannel - 1)
case 1: LG_TV0_ChannelNo.sendCommand(currentChannel + 1)
Your error message speaks the truth; you do not have an Item called LG_TV0_WOL
i deleted that item from Items file.
currently binding working fine but still some time while i powerd off & on tv it stopped working.
i will gather error data and revert back so you guys can help me.
thanks for reply.
