I’ve been using the LG WebOS Binding since the early days where it was named ConnectSDK Binding… an back in the days as i’ve set up my sitemaps, i was able to get a list of Apps for the application Item via the REST API… I’m pretty sure I was getting the list there, but cant remember how…
Since i’m setting up my UI to HabPanel… i was searching again… but i cant get the list of apps via REST API…
Did something changed or if not, can someone guide my the the right part of the Rest API where i can get the list?
I’m running on the latest snapshot build of OH…
this is a Old list which i got from a backup of my sitemap file… but mybe the list is longer… or the application names changed…
not sure what rest api would return those values. but you can enable debug logging for the binding and switch channels. You will find a list of all ids and their names in your log… watch out for: “AppInfo” in the log statements. btw. With the next release this will only happen once the TV goes online.
Pull Request #2926 was just merged. With the new 2.5 version you can use classic rules to fetch a list of applications available on the TV and launch apps as well.
val actions = getActions("lgwebos","lgwebos:WebOSTV:3aab9eea-953b-4272-bdbd-f0cd0ecf4a46")
if(null === actions) {
logInfo("actions", "Actions not found, check thing ID")
return
// list of applications
val apps = actions.getApplications
apps.forEach[a| logInfo("action",a.toString)]
// launch applications
actions.launchApplication("com.webos.app.tvguide") // TV Guide
actions.launchApplication("com.webos.app.livetv") // TV
actions.launchApplication("com.webos.app.hdmi1") // HDMI1
actions.launchApplication("com.webos.app.hdmi2") // HDMI2
actions.launchApplication("com.webos.app.hdmi3") // HDMI3
Hi there,
after upgrading from 2.5.5 to 2.5.7 I get this error message
21:43:37.082 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Switch Scene Netflix': 'getApplications' is not a member of 'org.eclipse.smarthome.core.thing.binding.ThingActions'; line 1220, column 13, length 23
Did something change in the 'org.eclipse.smarthome.core.thing.binding.ThingActions'?
