I’m able to control most functions like volume, input source and turning off the tv, but turning on won’t work. I know that you should use the WOL binding https://www.openhab.org/addons/bindings/wol1/
So I configured a item for that…
WOL.items:
Switch Network_OpenhabWebsite “WOL tv woonkamer” (Status, Network) { wol=“192.168.0.255#78:5d:c8:1a:49:c0” }
When I turn on the switch this is the log:
2019-06-30 12:42:09.255 [INFO ] [nhab.binding.wol.internal.WolBinding] - Wake-on-LAN packet sent [broadcastIp=192.168.0.255, macaddress=785dc81a49c0]
2019-06-30 12:42:09.260 [vent.ItemStateChangedEvent] - Network_OpenhabWebsite changed from OFF to ON
But the tv isn’t turning on, who knows what I’m doing wrong? They are in the same network because I’m able to control the other function…
Hi, I had issues getting my LG TV to turn on also, but there seems to be a bit of a weird thing happening on the TV and even though it is hard wired to the LAN I also need to enable the WOL for WiFi too in order to get it to work - Which it does now, without any issues.
My Rule:
rule "Power on TV via Wake on LAN"
Item LG_TV0_Power received command ON
sendCommand( LG_TV0_WOL, ON)
sendCommand( LG_TV0_WOL_WiFi, ON)
Thanks, I setup the items and rule the same as you have, when I check the logs I see that it sends the WOL signal to both MAC addresses but unfortunately the TV still won’t power on when I pull the switch…
Apparently it doesn’t seem to be possible with a LG 55EG9A7V…
I had the same problem with my LG 49SJ810V. My solution is similar to @dheneghan’s but I switched off the WiFi on the TV (in tv settings with LG remote) and only connect with LAN / UTP-cable because why need both? So I just need an item for the LG_TV_WOL. Make sure you set the MAC of the LAN-port in the item and not the Wifi-card’s.
Also consider the ip addresses, LAN might get a different one than WiFi.
What you could try is downloading a WOL utility for Windows (if that’s an OS you use) to send the magic packet, maybe to another machine on your network, see if it powers up. Or you could put a sniffer on your network to see if the magic packet is actually getting broadcast.
I’ve got no more issues. TV is on LAN, didn’t test on WLAN. Because I have subnet mask 255.255.0.0 i had to change the wol command to 192.168.255.255. first attempt was with the ip address of the tv, second was with the ending of ip to 255. But because I forgot the changed subnet I had to change last 2 segments of ip to 255.
192.168.178.60#xx:xx:xx:xx:xx - wrong
192.168.178.255#xx:xx:xx:xx:xx - wrong
192.168.255.255#xx:xx:xx:xx:xx - right
