I try to connect my Lg Tv (49ub820v, netcast 4.5) with openhab, pairing seems to be ok (lgtv connectionstatus of ip=192.168.1.52 changed from CS_NOTCONNECTED to CS_PAIRED), but still errors on the logs, and “CS_NOTCONNECTED”
Here the cfg file and logs
This error is quite bizarre because it looks like it does not find the ip of the tv in the configuration?
http://null:8080/udap/api/pairing
thanks in advance
[lgtv.cfg]
lgtv:lg.host=192.168.1.52
lgtv:lg.port=8080
lgtv:lg.pairkey=xxxxxx
lgtv:lg.serverport=8080
lgtv:lg.checkalive=60
[Logs]
[ERROR] [binding.lgtv.internal.LgtvConnection] - sendtotv but connection status is CS_NOTCONNECTED
[ERROR] [binding.lgtv.internal.LgtvConnection] - IO Exception at Connection to: http://null:8080/udap/api/pairing
[INFO ] [binding.lgtv.internal.LgtvConnection] - lgtv connectionstatus of ip=192.168.1.52 changed from CS_NOTCONNECTED to CS_PAIRED
[INFO ] [binding.lgtv.internal.LgtvConnection] - sendpairkey with result=200 successconnectionstatus=CS_PAIRED
[ERROR] [binding.lgtv.internal.LgtvConnection] - no pairkey defined
