The example configuration is actually for version 1.8.
Under Openhab2 you should go through the discovery process and bind the different channels. And make sure you use the OH2 version of the binding: Version 2 Releases
For a production setup I think the project still recommends Openhab 1.8.
But you can try it out with OH2 of course.
Yes, it is enabled. As I said, with OH1 it worked fine but after upgrading to OH2, I still not able to connect.
Using PaperUI, when I search for a thing, nothing appear.
Hi, may be small bug in OH2 binding, if i sending fast, one by one 3 or more toasts to LGTV errors in log:
23:55:09.168 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while calling handler: java.lang.ArrayIndexOutOfBoundsException
java.util.concurrent.ExecutionException: java.lang.ArrayIndexOutOfBoundsException
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_101]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_101]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)[98:org.eclipse.smarthome.core:0.9.0.201701140927]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)[98:org.eclipse.smarthome.core:0.9.0.201701140927]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)[98:org.eclipse.smarthome.core:0.9.0.201701140927]
at org.eclipse.smarthome.core.thing.internal.ThingManager.receiveCommand(ThingManager.java:369)[105:org.eclipse.smarthome.core.thing:0.9.0.201701140927]
at org.eclipse.smarthome.core.items.events.AbstractItemEventSubscriber.receive(AbstractItemEventSubscriber.java:46)[98:org.eclipse.smarthome.core:0.9.0.201701140927]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:192)[98:org.eclipse.smarthome.core:0.9.0.201701140927]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:1)[98:org.eclipse.smarthome.core:0.9.0.201701140927]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)[98:org.eclipse.smarthome.core:0.9.0.201701140927]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
Caused by: java.lang.ArrayIndexOutOfBoundsException
at java.lang.System.arraycopy(Native Method)[:1.8.0_101]
at com.android.internal.util.GrowingArrayUtils.insert(GrowingArrayUtils.java:118)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at android.util.SparseArray.put(SparseArray.java:207)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at com.connectsdk.service.webos.WebOSTVServiceSocketClient.sendCommand(WebOSTVServiceSocketClient.java:596)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at com.connectsdk.service.WebOSTVService.sendCommand(WebOSTVService.java:2893)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at com.connectsdk.service.command.ServiceCommand.send(ServiceCommand.java:70)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at com.connectsdk.service.WebOSTVService.sendToast(WebOSTVService.java:940)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at com.connectsdk.service.WebOSTVService.showToast(WebOSTVService.java:845)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at org.openhab.binding.connectsdk.handler.ToastControlToast.onReceiveCommand(ToastControlToast.java:51)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at org.openhab.binding.connectsdk.handler.ConnectSDKHandler.handleCommand(ConnectSDKHandler.java:73)[231:org.openhab.binding.connectsdk:2.0.0.201603250427]
at org.eclipse.smarthome.core.thing.internal.ThingManager$4.call(ThingManager.java:372)[105:org.eclipse.smarthome.core.thing:0.9.0.201701140927]
at org.eclipse.smarthome.core.thing.internal.ThingManager$4.call(ThingManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.201701140927]
... 5 more
