After performing FW update of my TV the lgwebos:WEBOSTV thing was offline.
I have removed the thing, run discovery and readded the thing, but thats not fixing the issue.
Within the new thing, there is no access key and no mac address (both were in the thing-config before I removed the old thing for testing).
There is no prompt on the TV to accept any connection.
I have set the log to trace:
2023-10-13 18:25:49.862 [DEBUG] [ebos.internal.handler.LGWebOSHandler] - Initializing handler for thing lgwebos:WebOSTV:347e3ed0-ff76-9deb-11fc-c239f697637d
2023-10-13 18:25:49.865 [TRACE] [ebos.internal.handler.LGWebOSHandler] - Handler initialized with config WebOSConfiguration [host=xxx, port=3000, key.length=0, macAddress=null]
2023-10-13 18:25:49.867 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - setState new DISCONNECTED - current DISCONNECTED
2023-10-13 18:25:49.870 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - Connecting to: ws://xxx:3000
2023-10-13 18:25:49.878 [TRACE] [bos.internal.handler.LGWebOSTVSocket] - Connection Error
java.io.EOFException: HttpConnectionOverHTTP@3ce209::SocketChannelEndPoint@f8696e{l=/xxx:41640,r=/xxx:3000,ISHUT,fill=-,flush=-,to=2/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@3ce209(l:/xxx:41640 <-> r:/xxx:3000,closed=false)=>HttpChannelOverHTTP@179147a(exchange=HttpExchange@123227a{req=WebSocketUpgradeRequest[GET / HTTP/1.1]@6ea77d[TERMINATED/null] res=HttpResponse[null 0 null]@1880287[PENDING/null]})[send=HttpSenderOverHTTP@db1908(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@efcf9b{s=START}],recv=HttpReceiverOverHTTP@1b3c134(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.earlyEOF(HttpReceiverOverHTTP.java:385) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1620) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.shutdown(HttpReceiverOverHTTP.java:269) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:185) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.46.v20220331]
2023-10-13 18:25:49.882 [DEBUG] [ebos.internal.handler.LGWebOSHandler] - Connection failed - error: HttpConnectionOverHTTP@3ce209::SocketChannelEndPoint@f8696e{l=/xxx:41640,r=/xxx:3000,ISHUT,fill=-,flush=-,to=2/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@3ce209(l:/xxx:41640 <-> r:/xxx:3000,closed=false)=>HttpChannelOverHTTP@179147a(exchange=HttpExchange@123227a{req=WebSocketUpgradeRequest[GET / HTTP/1.1]@6ea77d[TERMINATED/null] res=HttpResponse[null 0 null]@1880287[PENDING/null]})[send=HttpSenderOverHTTP@db1908(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@efcf9b{s=START}],recv=HttpReceiverOverHTTP@1b3c134(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
2023-10-13 21:52:40.803 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - setState new DISCONNECTED - current DISCONNECTED
2023-10-13 21:52:40.807 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - Connecting to: ws://192.168.58.136:3000
2023-10-13 21:52:40.819 [TRACE] [bos.internal.handler.LGWebOSTVSocket] - Connection Error
java.io.EOFException: HttpConnectionOverHTTP@164a0d::SocketChannelEndPoint@980361{l=/xxx:52168,r=/xxx:3000,ISHUT,fill=-,flush=-,to=3/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@164a0d(l:/xxx:52168 <-> r:/xxx:3000,closed=false)=>HttpChannelOverHTTP@2379b9(exchange=HttpExchange@17beed0{req=WebSocketUpgradeRequest[GET / HTTP/1.1]@1d18210[TERMINATED/null] res=HttpResponse[null 0 null]@17e1f00[PENDING/null]})[send=HttpSenderOverHTTP@b350e7(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@2627cf{s=START}],recv=HttpReceiverOverHTTP@1c0e359(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
2023-10-13 21:52:40.829 [DEBUG] [ebos.internal.handler.LGWebOSHandler] - Connection failed - error: HttpConnectionOverHTTP@164a0d::SocketChannelEndPoint@980361{l=/xxx:52168,r=/xxx:3000,ISHUT,fill=-,flush=-,to=3/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@164a0d(l:/xxx:52168 <-> r:/xxx:3000,closed=false)=>HttpChannelOverHTTP@2379b9(exchange=HttpExchange@17beed0{req=WebSocketUpgradeRequest[GET / HTTP/1.1]@1d18210[TERMINATED/null] res=HttpResponse[null 0 null]@17e1f00[PENDING/null]})[send=HttpSenderOverHTTP@b350e7(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@2627cf{s=START}],recv=HttpReceiverOverHTTP@1c0e359(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
Yes, since you stated that you were running 3.4.2 already and also set the useTLS parameter (which didn’t exist before 3.4.2), I did not have any other suggestions.
