LGWebOS Binding - Text message size still exceeds maximum size
Hello all
Release = Debian GNU/Linux 11 (bullseye)
Kernel = Linux 6.1.21-v8+
Platform = Raspberry Pi 4 Model B Rev 1.5
Uptime = 1 day(s). 3:28:46
CPU Usage = 3.02% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 0.37, 5m: 0.20, 15m: 0.18
Memory = Free: 1.68GB (45%), Used: 2.07GB (55%), Total: 3.75GB
Swap = Free: 2.99GB (100%), Used: 0.00GB (0%), Total: 2.99GB
Root = Free: 22.08GB (79%), Used: 5.68GB (21%), Total: 28.98GB
Updates = 0 apt updates available.
Sessions = 1 session(s)
openHAB 4.1.1 - Release Build
openjdk-17-jre-headless:arm64
LG TV: OLED55G39LA
WebOS: 8.3.0-15
LG WebOS Binding. Connection failed. Debug shows, that message size exceeded.
Log:
2024-02-01 15:06:35.994 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘LG39_Power’ changed from OFF to ON
2024-02-01 15:06:36.994 [DEBUG] [ebos.internal.handler.LGWebOSHandler] - Connection failed - error: Text message size [4316809] exceeds maximum size [4194304]
2024-02-01 15:06:36.995 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - WebSocket Closed - Code: 1009, Reason: Text message size [4316809] exceeds maximum size [4194304]
2024-02-01 15:06:36.995 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - setState new DISCONNECTED - current REGISTERED
I found this thread, which state the same issue, which has been fixed in increasing buffer size.
https://community.openhab.org/t/lgwebos-binding-for-lg-webos-tvs/4726/591
Removing not used apps and services from tv does not reduce the message size. It seems, that the tv announces all services.
Is there a workaround to increase the message size on OH or any other suggestions to resolve this issue?
Thanks in advance!
Regards Daniel
The previous change from 3 MB to 4 MB is this one:
https://github.com/openhab/openhab-addons/pull/10404
We can try to increase it again, for example to 5 MB.
Hi
OK, that would be great, thanks!
Does it make sense to limit the message size? Later on, 5MB will exceed again, I guess.
Regards Daniel
I guess the web socket API has a max size by default and we need to adjust it
Here is Jetty documentation:
This is a memory conservation option, memory over this limit will not be allocated by Jetty for handling text messages.
Fix proposed:
https://github.com/openhab/openhab-addons/pull/16399
Great, thanks!
Fix is now merged and so included in receipt 4.2 snapshots.
