There’s been a change to the LGWEBOS.
The appLauncher seems to work very good.
But the Channel, doesn’t work. There are lots of double channelnames found. And, apparently, no current channel number. I have a LG OLEDE6 with webos 3.0
This is definitely not a tutorial, so I have moved it, but I’m not sure what you are communicating, so I’m not sure if this a better category. Is this for a binding?
LG WEBOS is the binding. Channel (changed recently to keep the channel and the channelnames) is a channel (it’s a bit confusing with those names ) It’s very recently changed.
OK… this should go into the bindings category then
In OH 2.5.3, you have now only one channel named channel
. The channel channelName
was suppressed. The remaining channel still store the channel number but there is dynamic options automatically built that allow any UI to display the channel number + the channel name and let the user to select his channel from a selection.
