Purpose: Perform licence plate recognition from a camera and store the plate numbers in a database for further processing.
Setup:
- Dahua IPC-HFW5231E-Z12 camera (2MP 12x zoom). Dahua’s IVS / Motion trigger is set up to trigger the event with ipcamera binding
- BlueIris continuously records the video stream from the camera and it serves snapshot images (among other things) on its own http server
- OpenALPR-HTTP-Wrapper docker
- ipcamera binding connects to the dahua camera directly for event alerts to openhab
- Jruby for scripting,
image_voodoogem for cropping,jdbc-sqlite3+sequelgems for sqlite access - The captured images are saved in OPENHAB_CONF/scripts/plates/ and kept for 30 days.
- The resulting data (timestamp, recognised plate number) is saved in an sqlite database and a plain text
Blueiris’ role for this sc is simply as a source for getting the snapshots from the camera. I tried getting the snapshot directly from the camera, but it seems to be too slow and as a result, the vehicle had already disappeared from the camera.
Items:
Group Street_Camera "Street Camera" <camera> (gOutdoor) ["Camera"] {snapshot_url="http://192.168.1.15/image/lpr?h=1080"}
String Street_Camera_EventData (Street_Camera, CameraEventData) ["Status"] {channel="ipcamera:dahua:street:lastEventData"}
Note the metadata snapshot_url could just be set on the Street_Camera_EventData to make things easier. Just adjust the code accordingly.
It’s stored as item metadata to support multiple cameras, each will have its own unique snapshot url.
Code:
# frozen_string_literal: true
require 'openhab'
require 'json'
require 'net/http'
gemfile do
source 'https://rubygems.org'
gem 'image_voodoo'
gem 'jdbc-sqlite3'
gem 'sequel'
PLATE_PATH = OpenHAB.conf_root / 'scripts' / 'plates'
PLATE_FILE = PLATE_PATH.parent / 'plates.txt'
PLATE_DB = PLATE_PATH.parent / 'plates.db'
OPENALPR_URI = URI('http://192.168.1.10:5000/detect')
# Add more cameras here
CAMERA_IDS = { Street_Camera => 0 }.freeze
DB = Sequel.jdbc("sqlite:#{PLATE_DB}")
DB.create_table? :captures do
primary_key :capture_id
DateTime :timestamp, default: Sequel::CURRENT_TIMESTAMP, index: true
Integer :camera_id, default: 0, index: true
String :plate, size: 10, index: true
String :snapshot_file
DB.create_table? :plates do
String :plate, size: 10, primary_key: true
String :notes
# This table is to manually correct some common mistakes of familiar plates, e.g. 338ZZZ -> 388ZZZ
DB.create_table? :plate_corrections do
String :raw_plate, size: 10, primary_key: true
PLATES = DB[:plates]
CAPTURES = DB[:captures]
PLATE_CORRECTIONS = DB[:plate_corrections]
# Holds a snapshot image with timestamp
class Snapshot
attr_reader :image, :timestamp, :source
@@camera_mutex = Mutex.new
# Initialize with an image object
def initialize(image, source)
@timestamp = Time.now
@image = image
@source = source
# take a snapshot from the given camera
def self.capture(camera)
url = camera.meta['snapshot_url'].value
image = @@camera_mutex.synchronize { Net::HTTP.get(URI(url)) }
Snapshot.new(image, camera)
# if necessary, calls lpr to recognize the plate
def plate
@plate ||= lpr(@image) || ''
# Return true if we have a valid plate
def plate?
!plate.empty?
def to_s
"#{timestamp} #{@plate}"
# Submit the given image to openalpr-http-wrapper service and return the JSON data
# @param [Binary] image the binary jpg image data to process
# @return [Hash] the returned json data as a Ruby hash, or nil if unsuccessful
def openalpr(image)
uri = OPENALPR_URI
req = Net::HTTP::Post.new(uri)
req.set_form([['upload', image, { filename: 'image.jpg' }]], 'multipart/form-data')
res = Net::HTTP.start(uri.hostname, uri.port) { |http| http.request(req) }
JSON.parse(res.body) if res.is_a? Net::HTTPSuccess
# Crop the given image
# @param [Image] image the binary image data
# @param [Array] rect rectangle to crop, an array with 4 elements: left, top, right, bottom
# @return [Image] The cropped image
def crop_image(image, rect)
ImageVoodoo.with_bytes(image).with_crop(*rect).bytes('jpg')
# Perform the LPR with the given image and
# return the plate with the highest confidence
# This will also crop the bottom of the image to remove
# The timestamp that's baked in by the camera
# @return [String] The recognised plate or nil
def lpr(image)
# crop the timestamp on the lower part of the image
image = crop_image(image, [0, 0, 1920, 1000])
result = openalpr(image)
result&.dig('results')&.sort_by { |res| res['confidence'] }&.last&.dig('plate')
rescue StandardError => e
logger.error e.message
nil
# { camera_id => array of Snapshot }
@snapshots = Hash.new { |hash, key| hash[key] = [] }
@snapshot_mutex = Mutex.new
@processing_queue = []
@processing_mutex = Mutex.new
# Save the given snapshot
# Append the plate to a text file
# @param [Snapshot] snapshot The snapshot object to save
def save_snapshot(snapshot)
time_str = snapshot.timestamp.strftime('%Y-%m-%d %k:%M:%S.%L')
lplate = snapshot.plate
filename = "#{time_str}-#{lplate}.jpg"
logger.info { "Saving recognised plate: #{time_str}: #{snapshot.image.length} #{lplate}" }
File.write(PLATE_FILE, "#{time_str} #{lplate}\n", mode: 'a') unless lplate.empty?
File.write(PLATE_PATH / filename, snapshot.image)
CAPTURES.insert timestamp: snapshot.timestamp,
plate: snapshot.plate,
snapshot_file: filename,
camera_id: CAMERA_IDS[snapshot.source]
# Given an array of snapshots objects
# Apply LPR and return the longest plate number
# @param [Array] snapshots An array of snapshot objects
# @return [Snapshot] One snapshot class containing the recognised plate number
def best_snapshot(snapshots)
snapshots
.select(&:plate?) # this will trigger the lpr on each snapshot
.group_by(&:plate)
.max_by { |plate, _snaps| plate.length }
&.pop&.first
# Process everything in the processing queue and empty it
def process_queue
snapshots = nil
@processing_mutex.synchronize do
snapshots = @processing_queue
snapshot = best_snapshot(snapshots)
save_snapshot snapshot if snapshot
# Add a set of snapshots to the processing queue
# And start a re-settable timer to process the queue shortly
# This will process multiple triggers of the snapshots
# to remove duplicates of the same car triggering multiple times
# @param [Array] snaps An array of Snapshot objects
def add_snapshots(snaps)
@processing_mutex.synchronize { @processing_queue.concat snaps }
after(3.seconds, :id => :process_queue) { process_queue }
# Get multiple snapshots 50ms apart and save them into
# the processing queue
# @param [GenericItem] camera The Camera item (Semantic Equipment)
# @param [Integer] count how many snapshots to take
# @param [Duration] interval the interval of the snapshots
# @param [Block] The block to be invoked once all the snapshots have been taken, passing the snapshots array
def initiate_lpr(camera, num_snapshots: 3, interval: 50.ms)
after(0.ms) do |timer|
next if timer.cancelled?
snaps = nil
@snapshot_mutex.synchronize do
last_snapshot = @snapshots[camera].length >= num_snapshots - 1
timer.reschedule(interval) unless last_snapshot
time = Time.now
logger.info { "Getting snapshot: #{@snapshots[camera].length + 1} #{time.strftime('%Y-%m-%d %k:%M:%S.%L')}" }
@snapshots[camera] << Snapshot.capture(camera)
snaps = @snapshots.delete(camera) if last_snapshot
add_snapshots(snaps) if snaps
# Check whether a vehicle is detected
# The logic here highly depends on the type of camera in use and
# what data it provides. This particular implementation is for Dahua cameras
# @param [Hash] data The JSON data from ipcameras binding
# @return [Boolean] true if the data indicates that a vehicle may be detected
def vehicle_detected?(data)
return false unless data
data['Action'] == 'Start' || data['RegionName'] || data.dig('Object', 'ObjectType') == 'Vehicle'
rule 'LPR: Capture' do
# updated Street_Camera_LastMotionType # , to: 'lineCrossingAlarm'
updated Street_Camera_EventData
# delay 100.ms
run do |event|
if logger.debug_enabled? && event.respond_to?(:state)
logger.debug("Street Camera: #{Street_Camera_LastMotionType} #{Street_Camera_EventData}")
json = event.item.state.to_s
data = JSON.parse(json)
camera = event.item.equipment
initiate_lpr(camera) if vehicle_detected?(data)
# Return the file age in days
# @param [String] filename
# @return [Float] Number of days since the file was created
def file_age(filename)
(Time.now - File.ctime(filename)) / 86_400
rule 'LPR: Clean up old snapshots' do
every :day, at: '3am'
# on_start
run do
count = Dir.glob(PLATE_PATH / '*.jpg').select { |f| file_age(f) > 30 }.map { |f| File.delete(f) }.count
logger.info("Deleted #{count} old LPR snapshot images ") if count.positive?
# uncomment to manually trigger it for testing
# initiate_lpr(Street_Camera)
