Light Control Card
winux_lightcard
A widget suited for lights and dimmer items.
  • The whole area acts as dimmer control. Nice for touch displays.
  • Fully customizable in the widget configuration screen. All colors can be changed.
    See pictures below.
  • The switch can be either horizontal or vertical.
  • Color Templates added.
Default look:
1_default_yellow
The quick paste configs below can be applied like this:
quickpastemanual
Feel free to also post your configs in yaml code fences below.
It’s a nice way to quickly apply, store and share different looks.
Purple (quick paste config):
  bgcolorON: rgba(70, 0, 70, 1)
  switchONbgcolor: rgba(170, 0, 170, 1)
  sliderbgcolor: rgb(120, 0, 120, 1)
  switchorientation: false
  bgcolorOFF: rgba(28, 28, 29, 1)
  switchOFFbgcolor: rgba(20, 20, 20, 1)
  switchhandleOFFcolor: rgba(40, 40, 40, 1)
  switchhandleONcolor: rgba(240, 210, 240, 1)
  sliderlabelbgcolor: rgba(170, 0, 170, 0.5)
  devicefontcolor: rgba(240, 210, 240, 1)
  dimmerlabelfontcolor: rgba(240, 210, 240, 1)
2_purple
Orange (quick paste config):
  bgcolorON: rgba(100, 34, 7, 1)
  switchONbgcolor: rgba(100, 55, 0, 1)
  switchhandleONcolor: rgb(255,69,0)
  sliderbgcolor: rgba(200, 85, 0, 0.5)
  switchorientation: true
  sliderlabelbgcolor: rgba(100, 45, 0, 0.6)
3_orange
Mintgreen (quick paste config):
  bgcolorON: rgba(0,71,31,1)
  sliderbgcolor: rgb(0, 153, 66)
  sliderlabelbgcolor: rgba(0, 110, 48, 1)
  switchONbgcolor: rgb(0, 212, 92)
4_mintgreen
Red (quick paste config):
  bgcolorON: rgba(225,0,0,0.1)
  sliderbgcolor: rgba(225,0,0,0.5)
  switchONbgcolor: rgba(170,0,0,0.3)
  bgcolorOFF: rgba(50,0,0,0.1)
  switchhandleONcolor: rgba(245,0,0,1)
  switchhandleOFFcolor: rgba(245,0,0,0.1)
  switchOFFbgcolor: rgba(30,0,0,1)
  sliderlabelbgcolor: rgba(225,0,0,0.3)
5_red
Blue (quick paste config):
  bgcolorON: rgba(0,50,235,0.2)
  sliderbgcolor: rgba(0,50,235,0.5)
  switchhandleONcolor: rgba(200,200,255,1)
  switchONbgcolor: rgba(0,25,155,1)
  bgcolorOFF: rgba(0,25,135,0.1)
  switchOFFbgcolor: rgba(0,0,80,1)
  sliderlabelbgcolor: rgba(0,25,100,0.7)
  switchhandleOFFcolor: rgba(150,150,255,0.2)
6_blue
White (quick paste config):
  bgcolorOFF: rgba(60, 60, 60, 0.8)
  bgcolorON: rgba(100, 100, 100, 0.8)
  sliderbgcolor: rgba(250, 250, 250, 0.7)
  switchOFFbgcolor: rgba(70,70,70,1)
  sliderlabelbgcolor: rgba(255, 255, 255, 0.3)
  switchhandleOFFcolor: rgba(30, 30, 30, 1)
  switchhandleONcolor: rgba(245, 225, 0, 1)
  switchONbgcolor: rgba(140,140,140,1)
  devicefontcolor: rgba(20,20,20,1)
  roomfontcolor: rgba(25,25,25,0.8)
  dimmerlabelfontcolor: rgba(50,50,50,1)
7_white
Udated configuration screen:
Changelog
Version 0.2
  • Text color config added in the config screen.
  • Config restructured.
  • Many typos fixed and hopefully added some new ones :smiley:
  • Color configs added. See Above.
Version 0.1
  • initial release
Resources
uid: winux_lightcard
tags:
  - light
  - switch
  - dimmer
  - madebywinux
props:
  parameters:
    - description: Item Name
      required: true
      type: TEXT
      groupName: labeling
    - description: Room Name
      required: false
      type: TEXT
      groupName: labeling
    - context: item
      description: Switch Item
      label: Item
      required: false
      type: TEXT
      groupName: items
    - context: item
      description: Dimmer Item
      label: Item
      required: false
      type: TEXT
      groupName: items
    - description: Icon name (Dynamic icons are supported)
      required: false
      type: TEXT
      groupName: icons
    - description: OFF = Horizontal orientation | ON = Vertical orientation.
      label: Vertical toggle orientation.
      required: false
      type: BOOLEAN
      groupName: items
    - description: Card background color | "ON" state
      required: false
      type: TEXT
      groupName: facecolors
    - description: Card background color | "OFF" state
      required: false
      type: TEXT
    - description: Switch backround color | "ON" state
      required: false
      type: TEXT
    - description: Switch background color | "OFF" state
      required: false
      type: TEXT
    - description: Switch handle color | "ON" state
      required: false
      type: TEXT
    - description: Switch handle color | "OFF" state
      required: false
      type: TEXT
    - description: Slider Color
      required: false
      type: TEXT
    - description: Slider label background color (dimmervalue background)
      required: false
      type: TEXT
    - description: Font color device name.
      required: false
      type: TEXT
      groupName: fontcolors
    - description: Font color room name.
      required: false
      type: TEXT
    - description: Label font color (dimmervalue).
      required: false
      type: TEXT
  parameterGroups:
    - name: labeling
      label: Name definitions
      description: Please enter a name for device and location.
    - name: icons
      label: Icon names.
      description: Please enter an icon name, e.g., lightbulb. Move (dynamic) icons into the conf/icons/classic/ directory.
    - name: items
      label: Widget Items
    - name: facecolors
      label: Face Colors
      description: Please enter color informations for the indivual face elements. No value = default widget element color. Use values like rgba(250, 0, 0, 1) for red or simply use the color name, e.g., red,blue,pink.
    - name: fontcolors
      label: Font/Text Colors
      description: Please enter color values for the indivual text element. No value = default widget text color.
timestamp: Oct 29, 2022, 4:42:57 AM
component: f7-card
  style:
    background: '=items[props.switchitem].state == "ON" && !props.bgcolorOFF  && !props.bgcolorON ? "rgba(255, 255, 0, 0.1)" : items[props.switchitem].state == "OFF" && !props.bgcolorOFF  && !props.bgcolorON ? "rgba(28,28,29,1)" : items[props.switchitem].state == "ON" && props.bgcolorOFF && props.bgcolorON ? props.bgcolorON : items[props.switchitem].state == "OFF" && props.bgcolorOFF && props.bgcolorON ? props.bgcolorOFF : items[props.switchitem].state == "OFF" && !props.bgcolorOFF && props.bgcolorON ? "rgba(28,28,29,1)" : items[props.switchitem].state == "OFF" && props.bgcolorOFF && !props.bgcolorON ? props.bgcolorOFF : items[props.switchitem].state == "ON" && !props.bgcolorOFF && props.bgcolorON ? props.bgcolorON : items[props.switchitem].state == "ON" && props.bgcolorOFF && !props.bgcolorON ? "rgba(255, 255, 0, 0.1)" : props.bgcolorOFF'
    border-radius: 20px
    max-height: 100px
    min-height: 100px
    overflow: hidden
    position: relative
slots:
  default:
    - component: f7-row
      slots:
        default:
          - component: f7-col
              width: 100
            slots:
              default:
                - component: oh-slider
                    item: =props.dimmeritem
                    label: true
                    max: 100
                    min: 0
                    releaseOnly: true
                    scale: false
                    step: 1
                    style:
                      --f7-range-bar-active-bg-color: '=props.sliderbgcolor ? props.sliderbgcolor : "rgba(255,240,0,0.5)"'
                      --f7-range-bar-bg-color: '=!items[props.switchitem].state == "ON" ? "transparent" : "transparent"'
                      --f7-range-bar-border-radius: 20px
                      --f7-range-bar-size: 100px
                      --f7-range-knob-color: transparent
                      --f7-range-knob-size: 0px
                      --f7-range-label-bg-color: '=!props.sliderlabelbgcolor == "" ? props.sliderlabelbgcolor : "rgba(150,150,0,0.7)"'
                      --f7-range-label-border-radius: 5px
                      --f7-range-label-font-size: 25px
                      --f7-range-label-font-weight: 400
                      --f7-range-label-padding: 0px 2px
                      --f7-range-label-size: 40px
                      --f7-range-label-text-color: '=props.dimmerlabelfontcolor ? props.dimmerlabelfontcolor : "rgba(255,255,255,0.9)"'
                      height: 100px
                      position: relative
                      width: 100%
                    unit: "%"
                    visible: "=props.dimmeritem ? true : false"
                - component: oh-toggle
                    class:
                      - '=props.switchorientation ? "large-vertical-toggle" : ""'
                    item: =props.switchitem
                    style:
                      --f7-theme-color: '=props.switchONbgcolor ? props.switchONbgcolor : "rgba(255,204,0,1)"'
                      --f7-toggle-border-color: rgba(0,0,0,0.5)
                      --f7-toggle-handle-color: '=items[props.switchitem].state == "OFF" && !props.switchhandleOFFcolor  ? "rgba(60,60,60,1)" : items[props.switchitem].state == "OFF" && props.switchhandleOFFcolor ? props.switchhandleOFFcolor : items[props.switchitem].state == "ON" && !props.switchhandleONcolor  ? "rgba(255,255,255,1)" : items[props.switchitem].state == "ON" && props.switchhandleONcolor ? props.switchhandleONcolor : items[props.switchitem].state == "OFF" && !props.switchhandleOFFcolor && !props.switchhandleONcolor ? "rgba(60,60,60,1)" : items[props.switchitem].state == "ON" && !props.switchhandleOFFcolor && !props.switchhandleONcolor ? "rgba(255,255,0,1)" : ""'
                      --f7-toggle-height: '=props.switchorientation ? "20px" : "40px"'
                      --f7-toggle-inactive-color: '=props.switchOFFbgcolor ? props.switchOFFbgcolor : "rgba(20,20,20,1)"'
                      --f7-toggle-width: '=props.switchorientation ? "40px" : "80px"'
                      position: absolute
                      right: 2%
                      top: '=props.switchorientation ? "calc(50% - 10px)" : "calc(50% - 20px)"'
                    visible: "=props.switchitem ? true : false"
          - component: f7-row
              style:
                overflow: hidden
                pointer-events: none
                position: absolute
                text-overflow: ellipse
                top: calc(50% - 29px)
                user-select: none
                white-space: nowrap
                width: 100%
            slots:
              default:
                - component: f7-col
                    style:
                      left: 2%
                      position: relative
                  slots:
                    default:
                      - component: f7-row
                        slots:
                          default:
                            - component: f7-col
                                style:
                                  min-width: 50px
                                width: 10
                              slots:
                                default:
                                  - component: oh-icon
                                      height: 54
                                      icon: '=props.icon ? props.icon : "lightbulb"'
                                      state: "=props.dimmeritem ? items[props.dimmeritem].state : items[props.switchitem].state"
                                      style:
                                        left: calc(50% - 27px)
                                        top: calc(50% - 27px)
                                        user-select: none
                            - component: f7-col
                                width: 40
                              slots:
                                default:
                                  - component: f7-row
                                    slots:
                                      default:
                                        - component: f7-col
                                          slots:
                                            default:
                                              - component: Label
                                                  style:
                                                    color: '=props.devicefontcolor ? props.devicefontcolor : "rgba(255,255,255,0.9)"'
                                                    font-size: 30px
                                                    font-weight: 400
                                                    left: 0
                                                    line-height: 30px
                                                    padding: 0px
                                                    text-shadow: 0px 2px 15px rgba(0, 0, 0,0.2)
                                                    user-select: none
                                                    mix-blend-mode: brighten
                                                  text: '=props.itemname ? props.itemname : "Bitte Namen eingeben."'
                                  - component: f7-row
                                    slots:
                                      default:
                                        - component: f7-col
                                          slots:
                                            default:
                                              - component: Label
                                                  style:
                                                    color: '=props.roomfontcolor ? props.roomfontcolor : "rgba(200,200,200,0.6)"'
                                                    font-size: 16px
                                                    left: 0
                                                    line-height: 16px
                                                    padding: 2px
                                                    text-shadow: 0px 0px 10px rgba(0, 0, 0,0.2)
                                                    user-select: none
                                                  text: '=props.roomname ? props.roomname : "Bitte Raumname (location) eintragen."'
                            - component: f7-col
                                width: 50
                              slots:
                                default:
                                  - component: Label
                                      style:
                                        color: rgba(250,250,250,0.6)
                                        font-size: 25px
                                        left: 0
                                        line-height: 50px
                                        text-align: left
                                        text-shadow: 2px 2px 5px rgba(0,0,0,0.2)
                                        user-select: none
Direct download: winux_lightcard.yaml rev 0.2
If you like what you see and want support further development, feel free to donate a coffee or some food :wink:
Good Work, thanks man!
I really like your widgets and I started with a remix for my Philips Hue lights - therefore it should support a button for scenes and a colorpicker. I took the code from the Philips Hue widget and started integrating, but unfortunatly the clicks on the colorpickers and the scene button do not work. Please give me a hint how to solve this issue. Here is the thread about that: Hue Widget Design Support
Thanks in advance and your good work!
Br Thomas
Hello, i’m glad you like it. Color select is not in yet because i like the simplicity and i didn’t want to clutter up the design that much. I thought about switch mode that will change the dimmer slider to a hue slider so one can change the color temperature (eg. warm to cold white). Maybe i can adapt that idea to also work for a color slider while keeping the desing simple. I have to look into it and i already have a little todo list of small tweaks and improvements that i will add at some point in time. If you create a swichgroup item containing the lights you want to be grouped and a dimmergroup item containing the respective dimmers, then set those 2 items in the config it should work. There is no meta info yet on how many lights and so on but the basics work.
Sorry, me a little slow at the moment because i’m kinda busy. I also just saw that Justin helped you already, nice of him. Cheers. :wink:
your work looks really great! I was wondering if you had considered applying the same approach to the list item widget?
Heya, thx. I will look into it and added it to the todo list.
Hi @winux, really great work. Like @PetrNemec I’d love to use it in an list item widget.
A very nice widget!
Is there an easy way to change the height of the widegt(smaller). So only change one entry? If no, which parameters must all be changed?
Hi guys, i will bring an update at some point after Openhab 4.0 is released.
Please don’t hesitate to improve or extend the widget if you like it. The code is above and it’s provided for free. If you want to help and improve it feel free to post the changes and i will update the topic when the time comes. If you can’t wait and want to have custom stuff being done then there is always the option to donate and tip the creator, this might speed up things ;).
@HolBaum5
The width of the widget will always be the width of the parent element you attach it to.
So if you watch the gif animation on top where i explain the quick paste config, look for “column options” in that menu flyout. You can configure all the widths of the parent element for different device/browser resolutions over there.
For the height change Line 120-121:
    max-height: 100px
    min-height: 100px
The rest of the elements need to be updated to the changes accordingly. Sorry, i don’t have more time at the moment to explain it all but i’m sure you will figure it out ;).
Have fun!
i am really grateful for this widget, i was searching for days for something like that.
I would like to add a Label to the Switch(oh-toggle) is that in anyway possible?
sure, i will add an option to disable/enable the button state display as text in the next update. If added it to the list. I’m using colors as feedback for the states, that’s why it’s not in there yet. But you are right, it’s good to have that as an option for color blind ppl and so on.
Thanks sounds good.
I would like to try on my own if you have a tipp where to start.
I can then share my code for everybody.
First… awesome work! Thanks for that widget. I have build it into my openHAB Overview page and everything is working like a charm. The only thing is, the widget is not visible in the iOS App. I am using the latest TestFlight Version and also, I am on the latest openHAB stable Version 4.0.2.
Can someone test, if the widget is shown in iOS?
i cannot acomplish light purple bgcolor of a dimmer it’s always black, double check it and everythink is pasted ok ? can you check your code?
I’m running OH4.3M1 and have a slider problem with this great widget.
@winux An ON/OFF item works fine with the switch, but when I add a Dimmer (hue or Zwave) item, the slider doesn’t show and on the left end of the widget I get an NaN% if I try to click on the slider.
The Dimmer Item is e regular Dimmer incl a slider in the Item itself.
Any thoughts?
Thank you for this nice Feature. I can only switch Lights ON.not Off.
Any Solution?
OpenHAB openHAB 4.3.2 Release Build
RaspberyyPI 4
AVM Fritz Bindings
component: widget:winux_lightcard
  itemname: Flur
  switchitem: Flur_Licht
  dimmeritem: Flur_Licht_Farbe
Thank you.
