O.k now here my first try to create this as an rule
import org.eclipse.xtext.xbase.lib.Functions
var Number nHueLevel
// Todo Hue kapseln in Lamda funtion
val Functions$Function4<DecimalType, GenericItem, GenericItem, GenericItem, String> LightLevel= [
DecimalType Lux,
GenericItem Kodi_online,
GenericItem gLivingRoomDimmer,
GenericItem gLivingRoomExtra|
logInfo("LichtLamda","Starten brechnung!")
//Todo avg auf 5 minuten?
//Todo wert noch auf Ganzahl runden
var Number nHueLevel = 100 - ((Lux / 300) * 100)
if (nHueLevel > 0 && Kodi_online.state == ON && gLivingRoomDimmer.state != nHueLevel) {
logInfo("Rule-Licht-Dimmen","Setze neuen berechneten Wert in Hue!")
sendCommand(gLivingRoomDimmer, nHueLevel)
if(gLivingRoomExtra.state == OFF && nHueLevel > 70){
sendCommand(gLivingRoomExtra, ON)
}else if (gLivingRoomExtra.state == ON && nHueLevel < 70){
sendCommand(gLivingRoomExtra, OFF)
} else if(gLivingRoomDimmer.state > 0) {
sendCommand(gLivingRoomDimmer, 0)
logInfo("lambdaHueLevel", nHueLevel.toString)
//s.state.toString + " logged"
nHueLevel.toString(); //return????
// ab 300 lux lampen hoch dimmen
rule "Licht dimmen wenn Fernseher an"
Item Zwave_Outdoor_Lux changed
//Wir berechnen den aktullen Lichtwert und damit den Hue Wert
LightLevel.apply(Zwave_Outdoor_Lux.state as DecimalType, Kodi_online, gLivingRoomDimmer, gLivingRoomExtra)
logInfo("Kodi-online.state", Kodi_online.state.toString())
rule "Kodi event on"
Item Kodi_online changed from OFF to ON
logInfo("Rule-Licht-Dimmen","Licht an ! Kodi_online is ON!")
rule "Kodi event off"
Item Kodi_online changed from ON to OFF
// todo irgenwie anlassen wenn es manuell war?
logInfo("Rule-Licht-Dimmen","Licht aus! Kodi_online is OFF!")
The Items are:
Switch Kodi_online { channel="network:device:kodi:online" }
Group:Switch:OR(ON, OFF) gLivingRoom "Wohnzimmerlicht" ["Switching"]
Group:Dimmer gLivingRoomDimmer "Dimmer"
Group:Color gLivingRoomColor "Farbe"
Group:Dimmer gLivingRoomColorTemp "Color temp"
Number Zwave_Outdoor_Lux "Motion Sensor [%.2f Lux]" <sun> (Zwave_Outdoor, gChart) { channel="zwave:device:0332b7c8:node2:sensor_luminance" }
Questions:
Kodi_online as networt item, because i don´t know how to gets the state of an thing (online/offline) inside an rule?
Also this line:
return an BigDecimal, how to round it to int)
How to get an avg from an Item?
Persitence is rrd4j databases, every minute but :
Zwave_Outdoor_Lux.averageSince(now.minusMinutes(5))
return 0
Thanks!
