Can you pm me the files above so I can check them
Yes all working now, thanks for the help, me know if you fix the dimmer which you mentioned had issues. I am now working on the graphical interface - habpanel, its the part i enjoy most.
You need to replace line 318
Features_OpenhabItemType == "String "){
with
(Features_OpenhabItemType == "String " || Features_OpenhabItemType == "Dimmer ")){
That should fix the dimmers
Youāll need to run āUpdateā again after that edit
LATEST FILES
have removed hard paths
have added dimmer as per Alex Fix
Lw_Base_v2.0_2019-10-25.rules.txt (25.7 KB)
Lw_Setup_v2.0_2019-10-25.items.txt (32 Bytes)
Just an update of v2, Iām gonna chase lw this week as havenāt heard since before xmas
Still no update back from lightwave (chased but no response)
Does anyone have any unresolved issues with v1 or v2 versions of my script that still need looking at while Iām waiting?
Oh and if people donāt want access to anything other than switches (no power monitoring etc) and have amazon you can use this:
Hi Iām trying to get this to work, however I keep seeing this message under ācontrolā in the PaperUI
sh: 0: Canāt open /openhab/conf/scripts/Lw_Get.sh
Its under one of the switches, i cannot switch anything on or off & above any switches i have ācommandā
Thanks.
Have you run the setup, and is that the correct path for your openhab installation (/openhab/conf/)
I pushed the button āLw_Setupā first then after about 10 seconds I pushed āLwUpdateā. it poplulates the control panel with the above image and thats where im stuck. paths are correct, it makes the other scripts ok just not that one.
Is /openhab/conf the correct path?
Yep, all the other scripts appear in the āscriptsā folder, just not that one for some reason.
Can you check the logs in /openhab/userdata/logs/ (specifically openhab.log) and see if there are any errors when you run setup
2020-01-11 09:02:09.251 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule āLwUpdate_Createā: For input string: ā{āmessageā:āUnauthorizedā}ā
I have this in my log after i try and run it - my username and password is correct - just tested it in the smart connect login page on lightwave?
Can you set Authentication_Switch to ON and see if you get any errors
Clicked the auth switch but it turns straight back off again?
It will, but you should see:
Authentication Rule Ran
and
Refresh Token Changed Toā¦
In the logs if it did anything
this is in the log:
2020-01-11 11:24:00.700 [INFO ] [ipse.smarthome.model.script.Lw.Rules] - Refresh Token Changed To Refresh_Token (Type=StringItem, State={null}, Label=null, Category=null)
