dont think it can connect to the net.
that comes up when login fails (http request returns a 404 not found)
Really weird as everything else is okay, Alexa binding etc
Is the certificate you loaded still there? could you have loaded it wrong?
Wrong password
Well at least it’s an easy fix
@delid4ve does the http request return a different error for that, maybe able to catch it?
What version were you running, going to spin up a docker with an older version to confirm I get the same
Now i’m running openhab 2.5.1 stable
What were you running when you had the first errors
2.5 stable ( 2.5.0-armhf-debian ) and 1.0.6 binding
If it helps anyone, I’ve repurposed some of @delid4ve 's original script to dump your LWRF structure and other info into the log. I’ve found this helpful several times when trying to diagnose various issues:
rule "Get LWRF Structure"
Item LWRF_Test_Switch received command ON
logInfo("LWRF-TEST.rules", "Rule Started")
logInfo("LWRF-TEST.rules", "Authentication Started")
var String username = "xxxxxxx@example.com" // Your LWRF username goes here
var String password = "yourpassword" // Your LWRF password goes here
val Get_Token = executeCommandLine("curl@@-X@@POST@@https://auth.lightwaverf.com/v2/lightwaverf/autouserlogin/lwapps@@-H@@Content-Type: application/json@@-H@@x-lwrf-appid: ios-01@@-d@@{\"email\" : \"" + username + "\",\"password\" : \"" + password + "\"}",5000)
var String RefreshToken = transform("JSONPATH", "$.refresh_token" , "{" + Get_Token.substringBetween("\"tokens\":{","}}") + "}")
var String AccessToken = transform("JSONPATH", "$.access_token" , "{" + Get_Token.substringBetween("\"tokens\":{","}}") + "}")
Refresh_Token.postUpdate(RefreshToken)
Access_Token.postUpdate(AccessToken)
logInfo("LWRF-TEST.rules", "Refresh Token - " + RefreshToken)
logInfo("LWRF-TEST.rules", "Access Token - " + AccessToken)
logInfo("LWRF-TEST.rules", "Authentication Finished")
Thread::sleep(3000)
logInfo("LWRF-TEST.rules", "Structure Dump Started")
var String Structure_GET = executeCommandLine("curl@@-s@@-g@@-XGET@@https://publicapi.lightwaverf.com/v1/Structures@@-H@@Authorization:bearer " + AccessToken,5000)
var String Structure_Value = transform("JSONPATH", "$.structures" , Structure_GET)
var Structures_GET = executeCommandLine("curl@@-s@@-X@@GET@@https://publicapi.lightwaverf.com/v1/Structure/" + Structure_Value + "@@-H@@Authorization:bearer " + AccessToken,20000)
var Devices_Count = Integer::parseInt(transform("JSONPATH","$.devices.length()", Structures_GET).toString)
logInfo("LWRF-TEST.rules", "Structures - " + Structure_Value)
logInfo("LWRF-TEST.rules", "My Structure - " + Structures_GET)
logInfo("LWRF-TEST.rules", "Device Count - " + Devices_Count.toString)
logInfo("LWRF-TEST.rules", "Structure Dump Finished")
logInfo("LWRF-TEST.rules", "Rule Finished")
Items:
Switch LWRF_Test_Switch
String Refresh_Token
String Access_Token
