Complete beginner so probably due to my lack of knowledge. When a switch is switched on from the iPhone app the broadcast packet contains “!R2D4F1|La mp 3|” but when broadcast from openHAB it looks like this “!R2D4F1.”. It does not appear to contain any instruction to turn on. Please see below the sitemap file:
I can’t help with the specific problem but I do see some errors in the Item you posted.
Light1 is not a members of Lights
You have no Lights_Control Group
Light 1 is an Item, not a Group, and even if it were a Group, a Group cannot be a member of itself
Everything in the ( ) must be the name of a Group, not an Item, and it must not be the name of the Group currently being defined. In other words, it makes no sense to put “Light1” in the parens.
Please see below the update items file. Not sure why the on or off command is not sent it just broadcasts the room & device ID’s? Presume the binding should do this?
