LightwaveRF + OpenHab2
I too am just starting to use LW with OH2. You are not alone :slight_smile:
I’m using it daily but I currently do it via the rfxcom binding rather than the openhab one (which I wrote). At some point I’ll try to port it but I don’t even use openhab2 yet so it isn’t high on my todo list.
I’m using Neil’s LightwaveRF binding with OH2. It works fine for dimmers and sockets but not for heating. The error message says it can’t decode the LWRF message. I suspect this may be because the message no longer contains the "signal " parameter.
I would suggest commenting out the line in the code that tries to parse this part of the LWRF message.
I’m happy to try this but I don’t immediately know how to create and edit bindings. If anyone else wants to give that a go, you may we’ll get to it before I have time.
Sorry to drag this thread back, but link no longer works. Anyone got the newest version of this binding?
works for me - I’m on 2.2.0-snapshot build #1098
I have org.openhab.binding.lightwaverf-1.11.0-SNAPSHOT.jar in my conf/addons folder.
I have the default lightwave.cfg in my conf/services folder as copied below for reference
The exact steps to upgrade I took were to first upgrade the lightwaverf binding from 1.9 to 1.11, then some weeks later I upgraded opehnab from build 560 to 1098. I didn’t get any outage.
From going from lightwaverfbinding 1.9 to 1.11 I notice I occasionally get ā€œError transmit failedā€ on my lightwaverf hub if I switch items manually too quickly, so perhaps the default 2 second delay is insufficient.
What does your log:tail show when you save the new lightwaverf binding .jar into the services folder?
################################### LightwaveRf Binding #####################################
# The IP Address of the LightwaveRf Wifi Link you can use the broadcast address (required)
lightwaveRf:ip=255.255.255.255
# The port to monitor for messages you shouldn't need to change this
lightwaveRf:receiveport=9760
# The port to send messages on, it will also be monitored for incoming messages
# you shouldn't need to change this
lightwaveRf:sendport=9761
# For a new computer you will need to register it with the wifi link to be allowed to send messages
# setting this to true we will send a registration message on startup. You will need to confirm
# registration on the wifi link. There is no harm leaving this as true but you can set to false
# once you have registerd for the first time.
lightwaverf:registeronstartup=true
# Delay between sending messages in ms to avoid swapming Wifi Link
lightwaverf:senddelay=2000
# Timeout for OK Messages in ms, we will retry messages we don't receive an ok for in the timeout
lightwaverf:okTimeout=1000
I have a brand new install of openhab2 running on a mac.
I can’t find the newest jar file and I don’t have a degree in GitHub.
I found an old copy of the jar file (1.10) nothing happened when I dropped the jar file in so I restarted openhab service. Then I get this:
13:27:26.665 [ERROR] [org.openhab.binding.lightwaverf     ] - FrameworkEvent ERROR - org.openhab.binding.lightwaverf
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.lightwaverf [184]
  Unresolved requirement: Import-Package: org.openhab.core.binding
	at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
Ok solved that by running
openhab-runtime-compat1x
in the karaf console. Cool just need to fight with it to get it paired :slight_smile:
I see - yes the last build of openhab1 addons on Cloudbees is blank. I don’t know how to retrieve a previous but I have the
1.11 .jar file on github:
copy to your conf/addons folder ( ensure permissions are correct) and let us know what it says in the log again?
very good
I guess you mean addons :wink:
Finally got it to pair (what a nightmare)
Had to restart openhab2 again
Now I get this in log, however it doesn’t seem to be listening, don’t see anything when I switch lights etc like usual:
13:58:26.094 [INFO ] [erf.internal.LightwaveRFSenderThread] - Ok message received for 100,!F*p
13:58:26.095 [WARN ] [htwaverf.internal.LightwaveRfBinding] - No item for incoming message[100,?V="N2.94D"
eek, well spotted, thanks corrected original post.
The binding doesn’t handle every message the Lightwave hub spits out - for example See my log below when I change a Switch item.
When you first install the binding, you have to authorise Openhab as a valid user of your lightwaverf hub - you’ll see a message on the the hub and you have to press a button.Did you do this - perhaps force a re-pair via instructions in openhab1-addons/bundles/binding/org.openhab.binding.lightwaverf at main Ā· openhab/openhab1-addons Ā· GitHub
14:03:26.367 [INFO ] [smarthome.event.ItemCommandEvent     ] - Item 'LWRF_OfficeLight' received command ON
14:03:26.371 [INFO ] [smarthome.event.ItemStateChangedEvent] - LWRF_OfficeLight changed from OFF to ON
14:03:26.481 [ERROR] [htwaverf.internal.LightwaveRfWifiLink] - Error converting message: *!{"trans":287,"mac":"xx:xx:xx","time":1512050606,"pkt":"433T","fn":"on","room":7,"dev":1}
14:03:26.514 [ERROR] [htwaverf.internal.LightwaveRfWifiLink] - Error converting message: *!{"trans":287,"mac":"xx:xx:xx","time":1512050606,"pkt":"433T","fn":"on","room":7,"dev":1}
14:03:26.578 [INFO ] [verf.internal.LightwaveRFSenderThread] - Ok message received for 257,!R7D1F1
Yep, did that, thats why I get ā€œOk message received for 100,!F*pā€
I had all this set up no problem on a raspberry pi previously (but it died).
For sure I used to get logs when I switched items from the iPhone app. Now I see nothing. Maybe the binding 1.11 broke it? I’ll try rolling back to 1.10.
edit nope still no luck…
edit2 Hmm I added some stuff to .items file, and edited sitemap and it works! Perhaps I just imagined that I used to see commands in the log…
I’ve done everything above. I get the ā€œOK message received for 100,!F*pā€ but then later in the logs I get:
2017-12-18 20:30:02.767 [ERROR] [erf.internal.LightwaveRFSenderThread] - Error waiting on queue
LightwaveRf binding isn’t shown in Bindings.
Full log details:
[twaverf.internal.LightwaveRfWifiLink] - Starting LightwaveRfWifiLink Connection
2017-12-18 20:29:09.993 [WARN ] [htwaverf.internal.LightwaveRfBinding] - No item for incoming message[100,?V="N2.94D"
2017-12-18 20:29:10.012 [INFO ] [erf.internal.LightwaveRFSenderThread] - Ok message received for 100,!F*p
2017-12-18 20:29:52.564 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2017-12-18 20:30:02.764 [INFO ] [twaverf.internal.LightwaveRfWifiLink] - Stopping LightwaveRfWifiLink Connection
2017-12-18 20:30:02.764 [INFO ] [erf.internal.LightwaveRFSenderThread] - Message not added to queue as we are shutting down Message[{}]
2017-12-18 20:30:02.765 [INFO ] [twaverf.internal.LightwaveRfWifiLink] - LightwaveRfWifiLink Connection Stopped
java.lang.InterruptedException
	at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.reportInterruptAfterWait(AbstractQueuedSynchronizer.java:2014)[:1.8.0_152]
	at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2048)[:1.8.0_152]
	at java.util.concurrent.LinkedBlockingDeque.takeFirst(LinkedBlockingDeque.java:492)[:1.8.0_152]
	at java.util.concurrent.LinkedBlockingDeque.take(LinkedBlockingDeque.java:680)[:1.8.0_152]
	at org.openhab.binding.lightwaverf.internal.LightwaveRFSenderThread.run(LightwaveRFSenderThread.java:111)[182:org.openhab.binding.lightwaverf:1.11.0.201711160210]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_152]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)[:1.8.0_152]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)[:1.8.0_152]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)[:1.8.0_152]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)[:1.8.0_152]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)[:1.8.0_152]
	at java.lang.Thread.run(Thread.java:748)[:1.8.0_152]
Any clues?
Uh, it’s possible I’m being really dumb here.
Just realised that there’s a 42s delay between the log entry for receiving the OK message from the Lightwave Link, and a message saying ā€œStopped Basic UIā€, which might well be me exiting because I couldn’t see anything!
Given that the Lightwave binding is an OpenHab1 binding, should I expect to see the Binding listed at all in the UI?
OK, all sorted … as an OpenHAB newbie, I was mistakenly expecting to see the Lightwave binding listed in the Paper UI.
I’ve now got a sitemap and a .items file configured, and LightWave is working just fine.
I have the binding working fine (and have done since v1) - but has anyone coded something neater on status logging?
Would love to get rid of these:
2018-01-17 20:51:46.601 [ERROR] [twaverf.internal.LightwaveRfWifiLink] - Error converting message: *!{"trans":14271,"mac":"03:3E:6E","time":1516222305,"pkt":"433T","fn":"dim","param":8,"room":2,"dev":2}
yes i have variations of these
2018-01-28 17:51:20.073 [ERROR] [twaverf.internal.LightwaveRfWifiLink] - Error converting message: *!{ā€œtransā€:512,ā€œmacā€:ā€œ20:53:59ā€,ā€œtimeā€:1517161879,ā€œpktā€:ā€œ868Rā€,ā€œfnā€:ā€œstatusPushā€,ā€œprodā€:ā€œvalveā€,ā€œserialā€:ā€œ365702ā€,ā€œtypeā€:ā€œtempā€,ā€œbattā€:3.12,ā€œverā€:56,ā€œstateā€:ā€œboostā€,ā€œcTempā€:24.2,ā€œcTargā€:26.0,ā€œoutputā€:100,ā€œnTargā€:20.0,ā€œnSlotā€:ā€œ18:15ā€,ā€œprofā€:7}
I have the most recent openHAB LightwaveRf Binding (28-Jan-2018 03:09:52) 1.12.0 SNAPSHOT
some more example working items/sitemaps for lightwaverf hardware would be appreciated
I think the problem might be that the binding expects to find a field called ā€œsignalā€, which has now been removed from the message by Lightwave in a recent (ish) firmware release.
I have tried to edit the source code but I can’t work out how to submit the edited version for build.
also i dont understand the building of the system to make slight alterations for testing, the code looks understandable
Hi Dave, I’m brand new to openHab but noticed your post from last year we Lightwaverf. I have several V1 LWrf devices (sockets, relays etc) and would like to get them integrated. But it looks like the LWrf bi ding is defunct as it doesn’t show up in the bindings on paperui. I see you’ve achieved a working system so would you be able to share how? I’m running openHab on a Pi 2. Any help would be gratefully received !!
Mark
