It would be good to add to it though as the V1 bridge seems to have had a firmware update pushed to it and now I get errors in the logs for new measures. Not the end of the world but not ideal.
I’m using the latest org.openhab.binding.lightwaverf-1.14.0-SNAPSHOT.jar but am still having no success with my LightwaveRF TRVs. My LightwaveRF link is currently running N2.94D.
Ive not discovered 1.14 as yet, I get the same error messages from my TRV’s .
As I understand it the binding does not understand that version of the LightwaveRF firmware, But asfaik the latest and greatest is totally uncompatable with the bindngs we have for LightwaveRF
I also have N2.94D
I am looking at ways of using the logging to get information into openhab, and or learning how to alter the binding
From what I can see in the code (bearing in mind I don’t know java), the messages seem to be parsed with REGEX. it would probably be more efficient to parse them as JSON.
There is definitely a change in the output messages in recent LWRF firmware. In particular, the signal strength is no longer part of the message. It is my guess (and I haven’t/don’t know how to checked the code in detail) that this is the cause of the error message and the failure to decode the message.
It’s a pity because the TRVs and room stat used to deliver current temperature readings (and other data) to OpenHAB. I never managed to get openHAB to control them.
I can understand why @neil_renaud stopped using LWRF heating devices (and hence stopped maintaining the binding). The TRVs are pretty poor.
I’ve now bought the rfxtrx433xl transceiver but the RFXCOM binding in OpenHab 2 does not seem to support it. Frustrating seeing as this unit is the latest unit from RFXCOM. Any ideas on how I can get it working?
Hi, the binding is a bit non logical to me, you add the rfcom binding then add a thing, a rfcom usb transceiver that has the config there is no choice of specific rfcom device just frequency selection and tick a load of protocols u many need, mine has spotted all sorts of local things to monitor
