I’m running openHAB 2.2 on a Windows 10 machine but I think that the limitation I encountered applies to all platforms using the basic UI.
It seems it is impossible to use dynamic icons If an item, such as Astro DayPhase, has a MAP file to convert a state such as DAYLIGHT to a more readable Day Light status in the basic UI. I found that the dynamic icons are mapped to the transformed state and not to the original state and that spaces in a dynamic icon name are not parsed.
So assuming we have the following icons:
The basic UI will successfully display the first 3 icons but will fail to display the last one due to the presence of a space in the file name.
Can anyone else confirm that it’s a know limitation and if this is the case is there any way to apply the MAP file on the original state of the item?
TIA
Claude
