Hi I followed the instructions found here:
To setup my linear garage door opener. I get the following error when using baseui that is created from the above. Also note that if I use the swagger rest UI setting the value of this device manually the device doesnt seem to respond either. I have tried this with two linear zwave garage units.
2019-04-09 09:50:42.857 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.zwave.handler.ZWaveThingHandler@24b98c0e’: null
at org.openhab.binding.zwave.internal.converter.ZWaveBarrierOperatorConverter.receiveCommand(ZWaveBarrierOperatorConverter.java:96) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.handleCommand(ZWaveThingHandler.java:1138) ~[?:?]
at sun.reflect.GeneratedMethodAccessor35.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.11.0.oh250M1]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.11.0.oh250M1]
at com.sun.proxy.$Proxy142.handleCommand(Unknown Source) [206:org.openhab.binding.zwave:2.5.0.M1]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.11.0.oh250M1]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.11.0.oh250M1]
at sun.reflect.GeneratedMethodAccessor34.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.11.0.oh250M1]
