- Platform information:
- openHAB version: 3.2M4
- Issue of the topic: I want to create a switch item that reflects if my dimmer is on ( dimmer > 0 )
I installed the Scale transformation
I setup a transform file DimmerToActiveStatus.scale
[..0]=OFF
]0..100]=ON
I linked a Switch to the dimmer
I set the profile on the link
The switch item becomes on when the dimmer is set above 0, but it never turns off
2021-11-11 18:03:22.776 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'OfficeLightOnState' received command OFF
2021-11-11 18:03:22.776 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'OfficeLightOnState' predicted to become OFF
2021-11-11 18:03:22.782 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OfficeLightOnState' changed from ON to OFF
2021-11-11 18:03:24.067 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OFF' with the file 'DimmerToActiveStatus.scale' : Scale must be used with numeric inputs, valid quantity types or a 'NaN' entry.
2021-11-11 18:07:26.554 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'OFF' with the file 'DimmerToActiveStatus.scale' : Scale must be used with numeric inputs, valid quantity types or a 'NaN' entry.
Any guidance on what I’m doing wrong?
