Could you help me to detect this message appeared after the migration?
2018-03-14 17:01:44.775 [INFO ] [el.core.internal.ModelRepositoryImpl]:
Validation issues found in configuration model 'home.sitemap', using it anyway:
Linkable widget should contain either only frames or none at all
It’s a problem in your sitemap structure. I believe it’s to do with the way things are nested.
Frame label="top frame" {
Text label="linkable widget, click for more" {
Text item=someItem label="this is fine on its own"
Frame label="but not allowed to mix frames and others on one 'level'" {
Text item=otherItem label="so this is broken"
Thank you for the details! I do have these structures exactly as you described. I was using the DSC Binding example, but I think it was my edits which caused the problem.
