I got a small problem with my Raspbian on Pi2. Yesterday it stucked second time during last quoter. Now I am trying to find a reason, but question is where to find it, where log I have to check ?
Openhab did not report any issues, but something happened:
red - processor usage
green - memory
blue - Openhab process
At 9 I have rebooted PI.
Before I was unable to use putty or Winscp (but ping was ok)
I have checked syslog and found followin items:
Jun 29 02:09:01 raspberrypi /USR/SBIN/CRON[14567]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -x /usr/lib/php5/sessionclean ] && [ -d /var/lib/php5 ] && /usr/lib/php5/sessionclean /var/lib/php5 $(/usr/lib/php5/maxlifetime))
Jun 29 02:10:01 raspberrypi /USR/SBIN/CRON[14593]: (root) CMD (/usr/bin/rrd.sh >/dev/null 2>/dev/null)
Jun 29 02:10:01 raspberrypi /USR/SBIN/CRON[14594]: (pi) CMD (/usr/bin/rrd.sh >/dev/null 2>/dev/null)
Jun 29 01:17:10 raspberrypi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Jun 29 01:17:10 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="1890" x-info="http://www.rsyslog.com"] start
Jun 29 01:17:10 raspberrypi kernel: [ 0.000000] Booting Linux on physical CPU 0xf00
Jun 29 01:17:10 raspberrypi kernel: [ 0.000000] Initializing cgroup subsys cpuset
Jun 29 01:17:10 raspberrypi kernel: [ 0.000000] Initializing cgroup subsys cpuacct
rrd it is my script, which generate charts, it works every 10minutes.
Is it possible that some system housekeeping process as maxlifetime generate processor overload ?
What does it mean next items ? Was it reseted, but if so why it stucked ?
