Linux SmartHome Designer Install and run
I downloaded the zip file to a folder. I do not see any documentation on how to run this program . Is there some command needed to exucute the program? I had no problem on my window box, but not sure how to fire it up on a linux box running OH2
assuming you are running Ubuntu / Unity:
  • check that java is installed
  • ceate folder e.g. “OpenHAB2-Designer”
  • extract zip into folder
    should look like so:
then you only need to Double-click “SmartHome-Designer”
First start may take a while. Finally, just do a right click on the Icon in Starter and select “Keep in starter”.
Worked for me.
HTH,
-OLI
Thanks for the info. I have done exactly that and nothing happens when I double click on the program. I know I have Java installed because I have OH2 running on the box while I am trying run the program
when you do a right click on the program file and select “Open with different program”(may not be 100% the right wording), what does it list? should look like so:
In a command prompt you can navigate to where you extracted the Designer and type ./SmartHome-Designer. This will show you any errors that may be popping up when you try to run it.
My install does do show the Java Runtime. I must have done something wrong during the install
I have the same Problem. I choose the OpenJDK Java 8 Runtime, but nothing happens if I double click.
If I do:
I get the error: Exec format error
Does anybody know a solution?
I am running a fresh linux mint os.
Greetings
felska
Does this designer work of OH1 as well?
If not, was there an OH1 designer that would run on Linux?
