List card in fixed grid layout
Hi all,
I’m trying to create a fixed grid layout in pages, but when I place a “List Card” on the canvas I’m not able to configure the list or add items to the list. Is this expected behavior, or is there any thing I’m missing? It works fine in responsive layouts.
Hi Morten,
Do you use the fixed grid or fixed canvas layout?
In the fixed grid layout I can configure the list card normally (OH 3.4.2).
In the fixed canvas layout I also cannot configure the list card as expected. I don’t know the reason, but you can edit the list card by clicking on the icon on the top right side of the widget and then choose “Edit YAML”.
Hi Diego,
Thank you for your reply. I use fixed canvas, but I’ll try to switch to the grid layout if there is no work around other than coding it in YAML for now.
Hi!
I’m facing the exact same Problem with OH 4.2.0. Can’t edit the list card widget on fixed canvas layout. Is there any solution to it yet?
it seems this is still a problem in the current version.
Or did someone find a workaround?
