I try to load bindings manualy. The sony binding works. One of this where not found in Logs and not found in PaperUI: [New Binding] EMBY Server Binding - Alpha
I have wrote there, but I hope for universal tipps what I can make if bindings (not only the emby binding) not loaded. The chown rights are correct.
Oh sorry. My english is not so good. My problem is that I don’t find information of the binding in PaperUI and in console I don’t see informations. Also I don’t find things in paperUI for this Plugin.
Do you know in whit file this is defined? When I found I can try to create a own jar file of the code and can try. But When i show the github repository I don’t find entries for openhab version.
There were many organizational changes between Mlestone 1 & 2 of 2.5. I am not a developer but in some bindings, paths needed to be changed. The build system was also changed at that time.
It was around that time I started with openHAB.
Something you can try is to use openhabian-config tool, from option 10 select “Apply Needed Packages” and see if that makes a difference. Also, while you’re there I would select “add svr mounts” and “fix permissions” just to make sure all is good.
