I want to have the ability to change the used icons in PaperUI via a simple file replacement in the conf-folder. I’ve read here Info to OH2 that you can simply put image files in conf/icons. But how do I use them in the PaperUI. Especially with Javascript.
For example: I use the file background.png" to display an image on the UI. To change this image, the only thing I have to do is to change the file in conf/icons.
Can you give me some hints or example code to retrieve the images in JS. Thanks
The Paper UI does not show any icons, so there is also no need to replace them
User icons are meant to be used for sitemap widgets and these are only supported in the normal UIs, such as the Classic UI and the Android & iOS apps.
Hmm, okay. I have customized the PaperUI and I do have some special Icons used in the UI.
Is there any possibility to load an image/icon in the PaperUI (JS or HTML) from a folder like conf or something? Actually I do pack a folder named img in the web-folder in the PaperUI jar. There I can place all my images and use them in the ui. But to change those images, I have to change the jar, which isn’t the best solution. Thanks
