Why not just follow the log files? They are located in /openhab/userdata/logs which should be mounted as a volume into the container which should also mean you can get to it from the host too. But tailis installed in the container so you could use
But in answer to your question, use log:tail instead of log:display.
When in the console, you can type the first part of any command followed by “–help” (e.g. log --help) and it will tell you all the valid subcommands.
openhab> log --help
SUBSHELL
log
COMMANDS
log:clear Clear log entries.
log:display Displays log entries.
log:exception-display Displays the last occurred exception from the log.
log:get Shows the currently set log level.
log:load-test Load test log.
log:log Log a message.
log:set Sets the log level.
log:tail Continuously display log entries. Use ctrl-c to quit this command
