My log is full of warning as seen below and also the UI shoows ERROR:COMM for a lot of z-wave devices.
Healing or reinitializing them works, but after a while it relapses to errors and warnings.
2022-09-17 15:48:22.950 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=23}]' on thing 'zwave:device:9062802f0c:node23' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:48:26.580 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=16}]' on thing 'zwave:device:9062802f0c:node16' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:51:42.879 [WARN ] [ebservice.UnavailableMieleWebservice] - Cannot re-emit device state for device '000176195174': The Miele cloud service is not available.
2022-09-17 15:51:42.890 [WARN ] [ebservice.UnavailableMieleWebservice] - Cannot re-emit device state for device '000176197992': The Miele cloud service is not available.
2022-09-17 15:51:42.898 [WARN ] [ebservice.UnavailableMieleWebservice] - Cannot re-emit device state for device '000105889721': The Miele cloud service is not available.
2022-09-17 15:51:42.914 [WARN ] [ebservice.UnavailableMieleWebservice] - Cannot re-emit device state for device '000138592099': The Miele cloud service is not available.
2022-09-17 15:51:42.934 [WARN ] [ebservice.UnavailableMieleWebservice] - Cannot re-emit device state for device '000712005847': The Miele cloud service is not available.
2022-09-17 15:51:42.957 [WARN ] [ebservice.UnavailableMieleWebservice] - Cannot re-emit device state for device '000176313748': The Miele cloud service is not available.
2022-09-17 15:51:45.692 [WARN ] [.accessories.HomekitAccessoryFactory] - Accessory of type MotionSensor must have following characteristics [MotionDetectedState]. Found only []
2022-09-17 15:51:45.695 [WARN ] [mekit.internal.HomekitChangeListener] - Cannot create accessory Item:BewegingsmelderEntree (Type=GroupItem, Members=5, State=NULL, Label=Bewegingsmelder Entree, Category=motion, Tags=[MotionDetector], Groups=[lEntree]) HomeKit type: 'MotionSensor' characteristic: 'Empty'
2022-09-17 15:51:45.754 [WARN ] [.accessories.HomekitAccessoryFactory] - Accessory of type Lighting must have following characteristics [OnState]. Found only []
2022-09-17 15:51:45.756 [WARN ] [mekit.internal.HomekitChangeListener] - Cannot create accessory Item:AchterdeurLumidora (Type=GroupItem, Members=4, State=NULL, Label=Achterdeur - Lumidora, Category=lightbulb, Tags=[Lightbulb], Groups=[lAchterdeur]) HomeKit type: 'Lighting' characteristic: 'Empty'
2022-09-17 15:51:45.788 [WARN ] [.accessories.HomekitAccessoryFactory] - Accessory of type MotionSensor must have following characteristics [MotionDetectedState]. Found only []
2022-09-17 15:51:45.790 [WARN ] [mekit.internal.HomekitChangeListener] - Cannot create accessory Item:BewegingsmelderBadkamer (Type=GroupItem, Members=5, State=NULL, Label=Bewegingsmelder Badkamer, Category=motion, Tags=[Equipment], Groups=[lBadkamer]) HomeKit type: 'MotionSensor' characteristic: 'Empty'
2022-09-17 15:52:05.590 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 39: Restore from config: Error. Data invalid, ignoring config.
2022-09-17 15:52:11.071 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 9: Device discovery could not resolve to a thingType! 0171:0003:0001::2.0
2022-09-17 15:52:13.985 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=14}]' on thing 'zwave:device:9062802f0c:node14' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.148 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=43}]' on thing 'zwave:device:9062802f0c:node43' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.148 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=action_heal; type=Boolean; value=false}, {key=action_reinit; type=Boolean; value=false}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=node_id; type=BigDecimal; value=6}]' on thing 'zwave:device:9062802f0c:node6' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.181 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=45}]' on thing 'zwave:device:9062802f0c:node45' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.200 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=38}]' on thing 'zwave:device:9062802f0c:node38' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.207 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=17}]' on thing 'zwave:device:9062802f0c:node17' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.207 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=42}]' on thing 'zwave:device:9062802f0c:node42' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.284 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=41}]' on thing 'zwave:device:9062802f0c:node41' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.297 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=23}]' on thing 'zwave:device:9062802f0c:node23' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.368 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=16}]' on thing 'zwave:device:9062802f0c:node16' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.381 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=47}]' on thing 'zwave:device:9062802f0c:node47' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.384 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=action_heal; type=Boolean; value=false}, {key=action_reinit; type=Boolean; value=false}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=node_id; type=BigDecimal; value=27}]' on thing 'zwave:device:9062802f0c:node27' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.416 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=48}]' on thing 'zwave:device:9062802f0c:node48' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.425 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=21}]' on thing 'zwave:device:9062802f0c:node21' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.432 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=49}]' on thing 'zwave:device:9062802f0c:node49' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.440 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=40}]' on thing 'zwave:device:9062802f0c:node40' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.507 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=28}]' on thing 'zwave:device:9062802f0c:node28' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.515 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=action_heal; type=Boolean; value=false}, {key=action_reinit; type=Boolean; value=false}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=node_id; type=BigDecimal; value=26}]' on thing 'zwave:device:9062802f0c:node26' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:14.515 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=46}]' on thing 'zwave:device:9062802f0c:node46' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:20.114 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=14}]' on thing 'zwave:device:9062802f0c:node14' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:41.749 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=16}]' on thing 'zwave:device:9062802f0c:node16' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:52:43.026 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=47}]' on thing 'zwave:device:9062802f0c:node47' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:53:21.297 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=28}]' on thing 'zwave:device:9062802f0c:node28' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:53:52.130 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=43}]' on thing 'zwave:device:9062802f0c:node43' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:02.549 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=46}]' on thing 'zwave:device:9062802f0c:node46' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:06.600 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=48}]' on thing 'zwave:device:9062802f0c:node48' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:38.620 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=38}]' on thing 'zwave:device:9062802f0c:node38' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:58.923 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 9: Device discovery could not resolve to a thingType! 0171:0003:0001::2.0
2022-09-17 15:56:59.208 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 39: Restore from config: Error. Data invalid, ignoring config.
2022-09-17 15:56:59.554 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=14}]' on thing 'zwave:device:9062802f0c:node14' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.555 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=action_heal; type=Boolean; value=false}, {key=action_reinit; type=Boolean; value=false}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=node_id; type=BigDecimal; value=6}]' on thing 'zwave:device:9062802f0c:node6' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.558 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=43}]' on thing 'zwave:device:9062802f0c:node43' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.562 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=38}]' on thing 'zwave:device:9062802f0c:node38' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.562 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=45}]' on thing 'zwave:device:9062802f0c:node45' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.570 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=17}]' on thing 'zwave:device:9062802f0c:node17' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.573 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=41}]' on thing 'zwave:device:9062802f0c:node41' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.577 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=42}]' on thing 'zwave:device:9062802f0c:node42' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.579 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=47}]' on thing 'zwave:device:9062802f0c:node47' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.581 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=action_heal; type=Boolean; value=false}, {key=action_reinit; type=Boolean; value=false}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=node_id; type=BigDecimal; value=27}]' on thing 'zwave:device:9062802f0c:node27' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.598 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=40}]' on thing 'zwave:device:9062802f0c:node40' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.592 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=49}]' on thing 'zwave:device:9062802f0c:node49' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.588 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=48}]' on thing 'zwave:device:9062802f0c:node48' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.591 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=21}]' on thing 'zwave:device:9062802f0c:node21' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.615 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=28}]' on thing 'zwave:device:9062802f0c:node28' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.616 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=46}]' on thing 'zwave:device:9062802f0c:node46' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.622 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=action_heal; type=Boolean; value=false}, {key=action_reinit; type=Boolean; value=false}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=node_id; type=BigDecimal; value=26}]' on thing 'zwave:device:9062802f0c:node26' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.633 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=23}]' on thing 'zwave:device:9062802f0c:node23' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:56:59.642 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=16}]' on thing 'zwave:device:9062802f0c:node16' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:57:16.488 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=action_heal; type=Boolean; value=false}, {key=action_reinit; type=Boolean; value=false}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=node_id; type=BigDecimal; value=6}]' on thing 'zwave:device:9062802f0c:node6' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:57:17.452 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=17}]' on thing 'zwave:device:9062802f0c:node17' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:57:17.564 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_reinit; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=16}]' on thing 'zwave:device:9062802f0c:node16' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
2022-09-17 15:57:21.001 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=config_80_1; type=BigDecimal; value=1}, {key=action_heal; type=Boolean; value=false}, {key=group_1; type=ArrayList; value=[controller]}, {key=config_82_2; type=BigDecimal; value=6500}, {key=config_81_2; type=BigDecimal; value=2700}, {key=node_id; type=BigDecimal; value=14}]' on thing 'zwave:device:9062802f0c:node14' blocked. This is most likely a bug: {config_82_2=The value 6500 does not match allowed parameter options. Allowed options are: [ParameterOption [value="5000", label="Cold White (0x1388 (5000k) ~ 0x1964 (6500k))"]]}
## Release = Debian GNU/Linux 11 (bullseye)
## Kernel = Linux 5.15.61-v8+
## Platform = Raspberry Pi 4 Model B Rev 1.1
## Uptime = 3 day(s). 5:54:4
## CPU Usage = 4.22% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.18, 5m: 0.17, 15m: 0.16
## Memory = Free: 1.23GB (33%), Used: 2.51GB (67%), Total: 3.75GB
## Swap = Free: 2.99GB (100%), Used: 0.00GB (0%), Total: 2.99GB
## Root = Free: 50.25GB (89%), Used: 5.86GB (11%), Total: 58.54GB
## Updates = 0 apt updates available.
## Sessions = 1 session(s)
## Processes = 129 running processes of 4194304 maximum processes
