I’m using openHAB 2.2.0 Release Build on a raspberry-pi and recently updated via apt-get.
I’ve mounted a /mnt/Openhab_log and stated that as my log-directory.
Logfiles should be written to my Synology NAS.
This worked perfectly untill I updated. Now the log-file is created but it stays at 0kb.
When I remove the file, it’s created again after a reboot, but still 0kb.
Reading the forum I found this post from @Benjy:
openHAB 2.2 logging broken
My output:
pi@raspberrypi-1:~ $ openhab-cli info
Version: 2.2.0 (Build)
User: openhab (Active Process 406)
User Groups: openhab tty dialout audio
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhab
OPENHAB_CONF | /etc/openhab2 | openhab:openhab
OPENHAB_LOGDIR | /mnt/Openhab_log | root:root
OPENHAB_BACKUPS | /var/lib/openhab2/backups | root:root
URLs: http://192.168.2.110:8080
https://192.168.2.110:8443
When I try to read this correctly, it states that only root has acces to OPENHAB_LOGDIR and OPENHAB_BACKUPS. Is this a correct conlcusion?
How should I ad openhab:openhab to this location?
I’m not a Linux hero…
Please type
sudo chown openhab: /mnt/Openhab_log /var/lib/openhab2/backups
https://linux.die.net/man/1/chown
To sort that out:
sudo
-> do this as super user
chown
-> change ownership
openhab
-> new owner (but wait… there is a colon so)
openhab:
-> new owner, use same ownership for group
long version is openhab:openhab
, so first part is the user, second part is the group, separated by the colon
/mnt/Openhab_log
and /var/lib/openhab2/backups
-> file (or folder) names for which the ownership should be changed
That’s strange…not allowed to
pi@raspberrypi-1:~ $ sudo chown openhab: /mnt/Openhab_log /var/lib/openhab2/backups
chown: changing ownership of '/mnt/Openhab_log': Operation not permitted
The Backup is changed. I’ll dig into the user-wrights of that /mnt/Openhab_log
hmm… is that a real mount?
I mount the NAS from my /etc/fstab
192.168.2.10:/volume1/Openhab_log /mnt/Openhab_log nfs defaults,noauto,x-systemd.automount 0 0
If there is a drive mounted to /mnt/Openhab_log
there will be no way to change the ownership for the root folder (i.e. Openhab_log
), so create a folder within Openhab_log
, change the ownership to this subfolder and change the settings for logging accordingly.
OK, I’ll give it a try.
What I don’t understand is when I (as user ‘pi’) go to /mnt/Openhab_log
I can create a text.txt file.
I would expect that this is only possible as root
That depends on permissions.
ls -l /mnt/
will show you the permissions for Openhab_log (maybe it’s dxrwxrwxrw
But even if its only dxrwxrwxr-
maybe pi is member of the group root
@Udo_Hartmann, thanks for your help. The user-rights are driving me crazy.
Even with a subdir it’s not working as expected.
I’ll start all over again with logging to a local dir and when that’s working trying to figure out the mounting-procedure again.
