Platform information:
- RPi 3B compute module with openhabian and openHAB 3.2.0
- 1 Gb RAM
- 16 Gb SD card class 10
After some hours running the logging stops and the log (:9001) show only the log names
When I check the logs they are read only.
Outputs from free -m:
[09:32:22] openhabian@<hostname>:~$ free -m
total used free shared buff/cache available
Mem: 972 567 53 1 351 387
Swap: 2647 17 2630
and also from FireMotD:
## CPU Usage = 32.65% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 5.29, 5m: 1.72, 15m: 0.61
## Memory = Free: 0.04GB (4%), Used: 0.90GB (96%), Total: 0.94GB
## Swap = Free: 2.58GB (100%), Used: 0.00GB (0%), Total: 2.58GB
## Root = Free: 6.54GB (48%), Used: 6.82GB (52%), Total: 13.97GB
I have read that it is not recommended to use Zram with SBCs with less than 1 Gb. As the memory log show 972 Mbyte it is slightly less and I wonder if this is significant.
Here is one of the last lines from syslog
Jan 10 06:50:12 <hostname>rsyslogd[820]: file '/var/log/syslog'[7] write error - see https://www.rsyslog.com/solving-rsyslog-write-errors/ for help OS error: Read-only file system [v8.2102.0 try https://www.rsyslog.com/e/2027 ]
Except for the logging, the system seems to work.
What may I do to get logging working as it should? Any help is appreciated
Best regards
Per
