Logging to database
I am trying to log information to database instead of files.
The logging config file org.ops4j.pax.logging.cfg has only RollingRandomAccessFile appender configured. Can we configure a database appender so that I can log information from the program to database (like mysql)?
Or is there any other simpler way to do this so that I can make my program to log information to database?
I haven’t used any of these 2 options, so you should check various log4j2 info in the internet:
  1. Graylog: GitHub - mp911de/logstash-gelf: Graylog Extended Log Format (GELF) implementation in Java for all major logging frameworks: log4j, log4j2, java.util.logging, logback, JBossAS7 and WildFly 8-12
  2. JDBC: https://www.boraji.com/log4j-2-jdbcappender-example
Info: Appenders :: Apache Log4j (many options)
In case of Graylog see Logging to graylog.
Regarding log4j2 you are limited to the appenders bundeled by ESH.
