Hi all,
This is my first post here so go easy on me. This is my first time using OpenHAB and I am trying to connect to a panel of devices that has already been configured on another installation in a college lab. The devices are all Insteon devices and they’re connected to an insteonhub. I am using a fresh install of OpenHAB2 on Windows Server 2012, highly debating switching to a Linux OS.
Anyhow, my insteonplm.cfg looks like this:
port_0=/hub2/username:password@hubIP:25105,poll_time=1000
insteonplm:poll_interval=300000
Whenever I open up the OpenHAB GUI and create a widget, add an item to it then try to adjust it I keep getting the following errors repeating:
2019-03-07 21:23:39.300 [ERROR] [nplm.internal.driver.hub.HubIOStream] - bad username or password. See bottom label of hub for correct login
2019-03-07 21:23:39.300 [ERROR] [nplm.internal.driver.hub.HubIOStream] - got exception while polling: java.io.IOException: login credentials incorrect
Like I’ve mentioned I’m a complete noob to this and just trying to navigate my way through. I have checked with others and the credentials are all correct. I know I’ve missed a step here or something but I figured I should, at the very least, be able to connect to this hub which has already been set up. Any help is appreciated.
