Hello all,
I would be happy if someone could help me to solve my problem:
(Raspi 4B, openhabian-Image v3.3 release)
I am in the process of setting up external access (as described in the documentation via nginx).
So far, the setup has progressed to the point where the reverse proxy requires a login.
(next step would be “Making Exceptions for Specific IP addresses”).
The address I call up (on my local LAN) is “http://ourhouse.fritz.box”.
The proxy login works (picture 1). Now, however, I have a problem after I have told the reverse proxy my access data. Afterwards, however, another login mask appears (from openhab itself?) and this does not accept my openhab access data, but appears again and again (picture 2)
However, if I bypass the proxy with “http://ourhouse.fritz.box:8080”, I immediately get to the openhab page.
What is wrong here?
server {
listen 80;
server_name ourhouse.fritz.box;
# server_name mydomain_or_myip;
# Cross-Origin Resource Sharing
add_header 'Access-Control-Allow-Origin' '*' always;
add_header 'Access-Control-Allow_Credentials' 'true' always;
add_header 'Access-Control-Allow-Headers' 'Authorization,Accept,Origin,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Content-Range,Range' always;
add_header 'Access-Control-Allow-Methods' 'GET,POST,OPTIONS,PUT,DELETE,PATCH' always;
add_header Set-Cookie X-OPENHAB-AUTH-HEADER=1;
proxy_set_header Authorization "";
location / {
proxy_pass http://localhost:8080/;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_read_timeout 3600;
auth_basic "Username and Password Required";
auth_basic_user_file /etc/nginx/.htpasswd;
# satisfy any;
# allow 192.168.178.0/24;
# allow 127.0.0.1;
# deny all;
This is the proxy login (is working)
This is the second login (not working)
