I have a Fire TV connected to Harmony. I created an item that uses the Fire TV Thing discovered through Harmony. For the dropdown item, I can control all keys except “Select”. Select key does nothing. maybe the text sent should be different? If I use the same “Select” from the TV dropdown then the TV sends the “Select” key thru HDMI and it works.
any suggestions?
no takers?
