Can you share your polling rule that updates the activity based on the pyHarmony response?
var livingroom_ip = "172.16.1.16"
rule harmony_activity_update
Time cron "0 0/1 * * * ?" //every 1 min
logDebug("HARMONY", "cron timed activity update")
var activity = executeCommandLine("harmony --harmony_ip " + livingroom_ip + " show_current_activity", 5000)
if (LivingRoomHarmony_Activity.state != activity) {
postUpdate("LivingRoomHarmony_Activity", activity)
rule livingroom_harmony_activity_changed
Item LivingRoomHarmony_Activity received command
logDebug("HARMONY", "Living Room Harmony activity changed to " + receivedCommand.toString)
var ret = executeCommandLine("harmony --harmony_ip " + livingroom_ip + " start_activity --activity " + receivedCommand.toString, 5000)
logDebug("HARMONY", ret)
That’s weird.
I am using the iOS App as well and it’s even starting up quicker
I assume it’s recognizing that there is no connection an skips this step!?
I did not see an impact on the functionality either. It’s working like before the crappy FW update.
I must admit that I usually don’t use the App at all - just the remote.
Yep , I will take a look this weekend and over the holidays. Super disappointed in logitech right now.
FYI, I was able to connect using a test Websocket app to one of my hubs, the response is not too different then what we got with xmpp. I’m optimistic we can fix this without too much breakage.
Need help? Got 3 hubs, 1 not used and can use for testing, and got time the next couple weeks.
Cheers,
-Th
FWIW, the folks at HA committed a fix earlier to use WS, kinda surprising how relatively small the changes they made were
Cheers,
-Th
Sounds great.
Thanks for sharing.
That would be really awesome if this would work and would enable us just to ignore Logitech’s ignorance!
Same effect with android, but I wasn’t sure if it was just in my mind.
I think I will block internet even if the firmware problem doesn’t exist anymore.
That definitely makes sense.
If I want to switch on TV, I will do it through OH anyway
Looks like Logitech is making headlines, this is one of the bigger German tech sites
For what it may be worth, I have just tweeted about it to some 4k techie followers. Please retweet to make it a little more visible to Logitech: https://twitter.com/rafaldotnet/status/1075688097420054528?s=21
Thats actually not most of the changes, they keep their own version of pyharmony which most of the websocket work was done in, GitHub - home-assistant/pyharmony: Python library for connecting to and controlling the Logitech Harmony Link .
I just tried to review the Harmony Hub on Amazon and got a pop up screen:
Unfortunately, we can not accept reviews of this article. There are restrictions on the submission of reviews for this product. This can be for a variety of reasons, such as unusual review activities.
Unbelievable!
Goodbye Logitech …
They should rename Logitech to LowTech !!
Yea, that is where I did it. But it was only accepted on the old hub version (and is not online yet, so let’s see what happens)
i was able to edit my review on amazon.it 2 days ago. better to do the same on the play store and app store for the harmony application
