Logout-Problem at energenie binding?
Hi together,
is there a known problem at logging out with energenie binding?
Today I encountered, that i can’t switch my LAN-PM with another client as my openhab-client PC or the openhab-sitemap-webbrowser.
If I call the LAN-PM IP-address in another browser, it says that “Impossible to login - there is an active session with this device at this moment.”. It is a little bit confusing, because the active session is not with the actual client, but with the openhab-server. If I open an browser on my openhab-Server PC, I’m already logged in. If I log me out manually, the openhab binding works, but is a little bit slow and delayed.
Also it seems that the energenie binding is not logging out at stopping openhab. After 10 min. (auto-logout) it is possible to login through another machine.
I’m not so firm with Java and the binding-source code but as I can see, in my opinion after every “sendOn” and “sendOff” function should the “sendLogOut”-function be called in a finally-block, to ensure that other clients can also connect to the energenie device.
Thanks in advance.
I will check if there is a problem with the log out.
Best
Hans-Jörg
Update: Just had a quick check at the code and can not see a problem there.
sendLogOut() when it should be. Could you please change your loglevel for energenie binding to “TRACE” and post the output here.
Hi @hmerk,
thank you for your response.
Here is the trace log:
2016-01-06 20:56:26.979 DEBUG o.o.b.e.i.EnergenieBinding[:167]- internalReceiveCommand() is called!
2016-01-06 20:56:27.038 TRACE o.o.b.e.i.EnergenieBinding[:200]- sendlogin to 192.168.178.39 with password 1
2016-01-06 20:56:27.039 TRACE o.o.b.e.i.EnergenieBinding[:201]- sending 'POST' request to URL : http://192.168.178.39/login.html
2016-01-06 20:56:27.200 TRACE o.o.b.e.i.EnergenieBinding[:217]- sending 'POST' request to URL : http://192.168.178.39
2016-01-06 20:56:27.201 TRACE o.o.b.e.i.EnergenieBinding[:218]- send command ON to socket 1 at host 192.168.178.39
2016-01-06 20:56:27.285 TRACE o.o.b.e.i.EnergenieBinding[:253]- logout from ip 192.168.178.39
2016-01-06 20:57:10.429 DEBUG o.o.b.e.i.EnergenieBinding[:93]- execute() method is called!
2016-01-06 20:57:10.502 TRACE o.o.b.e.i.EnergenieBinding[:118]- searchstring sockstates found at position 343
2016-01-06 20:57:10.505 TRACE o.o.b.e.i.EnergenieBinding[:122]- transformed state response = 1,0,0,0
2016-01-06 20:57:10.507 TRACE o.o.b.e.i.EnergenieBinding[:127]- Response for item Energenie_BlueRay = 0
2016-01-06 20:57:10.508 TRACE o.o.b.e.i.EnergenieBinding[:130]- transformed state for item Energenie_BlueRay = OFF
2016-01-06 20:57:10.604 TRACE o.o.b.e.i.EnergenieBinding[:253]- logout from ip 192.168.178.39
2016-01-06 20:57:10.665 TRACE o.o.b.e.i.EnergenieBinding[:118]- searchstring sockstates found at position 343
2016-01-06 20:57:10.667 TRACE o.o.b.e.i.EnergenieBinding[:122]- transformed state response = 1,0,0,0
2016-01-06 20:57:10.668 TRACE o.o.b.e.i.EnergenieBinding[:127]- Response for item Energenie_LED = 1
2016-01-06 20:57:10.668 TRACE o.o.b.e.i.EnergenieBinding[:135]- transformed state for item Energenie_LED = ON
2016-01-06 20:57:10.760 TRACE o.o.b.e.i.EnergenieBinding[:253]- logout from ip 192.168.178.39
2016-01-06 20:57:17.845 TRACE o.o.b.e.i.EnergenieBinding[:118]- searchstring sockstates found at position 343
2016-01-06 20:57:17.848 TRACE o.o.b.e.i.EnergenieBinding[:122]- transformed state response = 1,0,0,0
2016-01-06 20:57:17.849 TRACE o.o.b.e.i.EnergenieBinding[:127]- Response for item Energenie_FireTV = 0
2016-01-06 20:57:17.850 TRACE o.o.b.e.i.EnergenieBinding[:130]- transformed state for item Energenie_FireTV = OFF
2016-01-06 20:57:17.942 TRACE o.o.b.e.i.EnergenieBinding[:253]- logout from ip 192.168.178.39
As I can see the logout will be really called when it should, but maybe the “sendLogOut”-function is not correct implemented? I think the url should be in the format “String url = “http://”+pmsIp+“/login.html”;” for propper log out.
And not like this way: String url = “http://”+pmsIp;
private void sendLogOut(String pmsId) {
		String pmsIp = pmsIpConfig.get(pmsId);
		String url = "http://"+pmsIp;
		try {
			HttpUtil.executeUrl("POST", url, timeout);
			logger.trace("logout from ip {}", pmsIp);
		} catch (Exception e) {
			logger.error("failed to logout from ip {}", pmsIp);
Thanks for posting the trace logging.
I will check this again with wireshark to see what the origional ap does.
Best
Hans-Jörg
You don’t have to check this absolutely with wireshark.
  1. open the energenie-device-url in your browser
  2. login
  3. hover your mouse over the Logout hyperlink on the navigationbar → the link xxx.xxx.xxx.xxx/login.html will be called for logout.
I hope this helps you and the problem can be fixed for V1.8 :smile:
Thank you for your work!
Thanks David,
could reproduce this and validate your solution.
Bugfix is commited as pull request 3719 to github :
Fix a bug preventing proper logout from energenie devices #3719
Best
Hans-Jörg
perfect - thank you!
And merged, so will be available in 1.8.
Hi @hmerk,
now I’m on version 1.8 and I’m sorry about that, but I think there are still problems.
I noticed that because of some delay in switching on or off my energenie-power strip.
Sometimes there are a couple of seconds between the action to switch on or off and the real on or off at the power strip. Here is the trace log from one example:
2016-01-19 15:27:45.262 DEBUG o.o.b.e.i.EnergenieBinding[:149]- internalReceiveCommand() is called!
2016-01-19 15:27:45.324 TRACE o.o.b.e.i.EnergenieBinding[:182]- sendlogin to 192.168.178.39 with password 1
2016-01-19 15:27:45.325 TRACE o.o.b.e.i.EnergenieBinding[:183]- sending 'POST' request to URL : http://192.168.178.39/login.html
2016-01-19 15:27:45.491 TRACE o.o.b.e.i.EnergenieBinding[:199]- sending 'POST' request to URL : http://192.168.178.39
2016-01-19 15:27:45.492 TRACE o.o.b.e.i.EnergenieBinding[:200]- send command ON to socket 1 at host 192.168.178.39
2016-01-19 15:27:45.541 TRACE o.o.b.e.i.EnergenieBinding[:230]- logout from ip 192.168.178.39
2016-01-19 15:27:46.786 DEBUG o.o.b.e.i.EnergenieBinding[:149]- internalReceiveCommand() is called!
2016-01-19 15:27:46.848 TRACE o.o.b.e.i.EnergenieBinding[:182]- sendlogin to 192.168.178.39 with password 1
2016-01-19 15:27:46.850 TRACE o.o.b.e.i.EnergenieBinding[:183]- sending 'POST' request to URL : http://192.168.178.39/login.html
2016-01-19 15:27:47.016 TRACE o.o.b.e.i.EnergenieBinding[:217]- sending 'POST' request to URL : http://192.168.178.39
2016-01-19 15:27:47.017 TRACE o.o.b.e.i.EnergenieBinding[:218]- send command OFF to socket 1 at host 192.168.178.39
2016-01-19 15:27:47.056 TRACE o.o.b.e.i.EnergenieBinding[:230]- logout from ip 192.168.178.39
2016-01-19 15:27:47.944 DEBUG o.o.b.e.i.EnergenieBinding[:149]- internalReceiveCommand() is called!
2016-01-19 15:27:48.005 TRACE o.o.b.e.i.EnergenieBinding[:182]- sendlogin to 192.168.178.39 with password 1
2016-01-19 15:27:48.005 TRACE o.o.b.e.i.EnergenieBinding[:183]- sending 'POST' request to URL : http://192.168.178.39/login.html
2016-01-19 15:27:48.170 TRACE o.o.b.e.i.EnergenieBinding[:199]- sending 'POST' request to URL : http://192.168.178.39
2016-01-19 15:27:48.171 TRACE o.o.b.e.i.EnergenieBinding[:200]- send command ON to socket 1 at host 192.168.178.39
2016-01-19 15:27:48.208 TRACE o.o.b.e.i.EnergenieBinding[:230]- logout from ip 192.168.178.39
2016-01-19 15:27:49.178 DEBUG o.o.b.e.i.EnergenieBinding[:149]- internalReceiveCommand() is called!
2016-01-19 15:27:49.239 TRACE o.o.b.e.i.EnergenieBinding[:182]- sendlogin to 192.168.178.39 with password 1
2016-01-19 15:27:49.239 TRACE o.o.b.e.i.EnergenieBinding[:183]- sending 'POST' request to URL : http://192.168.178.39/login.html
2016-01-19 15:27:49.399 TRACE o.o.b.e.i.EnergenieBinding[:217]- sending 'POST' request to URL : http://192.168.178.39
2016-01-19 15:27:49.400 TRACE o.o.b.e.i.EnergenieBinding[:218]- send command OFF to socket 1 at host 192.168.178.39
2016-01-19 15:27:49.435 TRACE o.o.b.e.i.EnergenieBinding[:230]- logout from ip 192.168.178.39
2016-01-19 15:27:50.326 DEBUG o.o.b.e.i.EnergenieBinding[:149]- internalReceiveCommand() is called!
2016-01-19 15:27:57.403 TRACE o.o.b.e.i.EnergenieBinding[:182]- sendlogin to 192.168.178.39 with password 1
2016-01-19 15:27:57.404 TRACE o.o.b.e.i.EnergenieBinding[:183]- sending 'POST' request to URL : http://192.168.178.39/login.html
2016-01-19 15:27:58.567 TRACE o.o.b.e.i.EnergenieBinding[:199]- sending 'POST' request to URL : http://192.168.178.39
2016-01-19 15:27:58.569 TRACE o.o.b.e.i.EnergenieBinding[:200]- send command ON to socket 1 at host 192.168.178.39
2016-01-19 15:27:58.606 TRACE o.o.b.e.i.EnergenieBinding[:230]- logout from ip 192.168.178.39
As you can see, the last ON command was sent 7 seconds after the internalReceiveCommand() function was called.
Is it possible that there is ab bug anymore?
I don’t see any problem in the code or errors in the log, so this seems to be a timing issue on your openHAB server.
Best
Hans-Jörg
Hmmm,
do you or someone else know what the problem could be?
I mean for a openhab installation it is a relative powerful machine (Intel NUC “NUCPPYH”).
No other problems with openhab delays - only with energenie!
Thanks a lot!
