Yes its running i guess . It appears as default to repeat errors in the main openhab log. But nothing extra . Just ive seen the log roration stamp appear.
It populates paper ui things after being manually added in text files
No items being populated other than log rotation
@pauli_anttila might have some ideas but in the mean time could you set up the binding through Paper UI? Just to avoid any kind of typos in manual configuration. Or ist that 409 error related in configuring the binding through Paper UI?
And if that logRotated
channel is the only thing in your .items
file you then have no other channels linked.
I get 409 if i touch anything in paper ui regarding log reader binding.
I copied the config from the examples and checked the describers from paper ui
All example items are configured but stay blank i could clear them and try full paper ui. But the logreader binding is a manual placement in the necessary folder would it appear in paper ui by itself
So you first configured the binding manually and then tried to alter something through Paper UI?
Even if you put a somebinding.jar in addons folder that doesnāt meant that itās not configurable in Paper UI. You just have to add it to things first. Go to Paper UI -> Configuration and click the blue ball to add it.
Its all populated with all the channels correctly but if i hit tick i was gettng 409 error
Sorry Iām not following you here. What do you mean you āhit tickā?
I think we have few options here: 1. You remove all manual config and try only with Paper UI. 2. You post your whole .items and .things file so we can verify your config and maybe correct it. 3. Reinstall the binding and maybe reboot OH. (Weird web server errors like your 409 here could be from cache problems and restarting OH might help in those)
Ill try a fresh paperui approach later with a restart of openhab.
The tick refrence is for when you are in paper ui things editing
Thanks for input on this
The full restart of openhab has improved behaviour of the items i had correct, others I had used directly from examples were incorrect (note to self, dont assume examples are correct)
In some situations a manual configuration could be easier eg for example the setting of the
items needing to be log monitored.
Now It appears the counters are working for the events but only one of the stringsā¦ but progress
I saw you enabled DEBUG logging already so anything unusual there now?
String LastWarningEvent { channel="logreader:reader:Reader:lastWarningEvent" } working
String LastErrorEvent { channel="logreader:reader:Reader:lastErrorEvent" } working
String LastCustomEvent { channel="logreader:reader:Reader:lastCustomEvent" } working
Number WarningEventsMatched { channel="logreader:reader:Reader:warningEvents" } working
Number ErrorEventsMatched { channel="logreader:reader:Reader:errorEvents" } working
Number CustomEventsMatched { channel="logreader:reader:Reader:customEvents" } working
DateTime LogRotated { channel="logreader:reader:Reader:logRotated" } no entry ( but can take time to appear in the past )
Switch NewWarningEvent { channel="logreader:reader:Reader:newWarningEvent" } no entry
Switch NewErrorEvent { channel="logreader:reader:Reader:newErrorEvent" } no entry
Switch NewLastCustomEvent { channel="logreader:reader:Reader:newCustomEvent" } no entry
the last three are a trigger, a flag for an event, Will check with a rule
Yet to spot anything in debug of significance
logRotated does update only when log really rotates so nothing unusual there. Those last three channels are trigger channels. You do not define them in .items file. They can be used in rules. Look for example.rules section in binding readme to get a hint.
Iād say youāre good to go
Be nice if the paper ui mentioned the word Trigger
Best to add persistence to some things ( looking at LogRotated ), a steeper learning curve i think
Is there a way to handle the long strings in BasicUI example the String LastWarningEvent
I guess I could use the triggers in a rule to create my own specific logging
Donāt know why you want to persist any of these channels. The original idea of this binding was to get these parsed log lines to be sent further for example with telegram or mail action. Not to fil your database with errors.
I guess you mean something to chop it shorter to fit in the screen. No nothing usefull really. Maybe you can come up with a few proxy items and rules to shorten the line?
Anything is possible but is it going to be usefull in the end. If you want to fiddle around with logging thereās few good tutorials on the forum about modifying log settings to your needs. Just use the search.
Happy hacking!
This bindings pull request is now merged and you can soon find it in the SNAPSHOT builds. Good job @pauli_anttila!
/Miika
I canāt figure out, how to use the Error Blacklisting Patterns
If I want to blacklist e.g.
2018-05-17 11:00:41.815 [ERROR] [org.openhab.io.net.http.HttpUtil ] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
how do I have to fill in the PaperUI configuration parameters?
Thanks for your help.
To answer my question myself: File based configuration works by just adding the Error. Doing the same over PaperUI doesnāt work.
Can you share things for logreader?
Looking for following two : 1. Custom key word 2. Reading the mossquitto.log (other th
an openhab application log.8
you have to fill in the binding page for logreader inpaper ui
Thats my thing:
logreader:reader:openhablog[ refreshRate=1000, warningPatterns="WARN+", warningBlacklistingPatterns="Warning to block|another warning to block", errorPatterns="ERROR+", errorBlacklistingPatterns="Error to block|another error to block" ]
I donāt use custom key word and reading other logs (I even donāt know if it is possible).
