Logwiever
Hi
I have just switched to OH4 on Windows.
Is it correct that the “openHAB Log Viewer” is not available in the same way as in OH3 (Openhabian)?
/Torben
If you are talking about Frontail, yes, as this is a Linux tool.
Thanks for the aswer.
Ho do i get a log then?
I have found out to use the “log:tail” - are there other ways?
What about asking google for a nice Windows logviewer?
I did not test it and also have no experience if it works but as far as I understand node / nodejs is available for windows as well. So it should run, shoudn’t it ?
Ah, did forget it is a nodejs tool, so probably it might work.
This might help. Its a Java App that runs natively on windows that provides a Http server that serves up logs.
