Hi folks,
I’m looking for a water sensor, in order to see the water consumption in real time. Zwave better, but any other solution can be considered.
Please help me
Andrea
Hi folks,
Please help me
Andrea
I’ve got a couple of these connect to a esp8266. If you’re OK with the basic soldering I’d happily send you a the code for it.
Uses wifite and mqtt too send data. Cost? Less than a a round of beers
What’s the smallest flow rate these can pick up? Could they detect a dripping tap?
On mine I can get it to register down to a fast drip which is 0.1L/m Perhaps I could improve it in code as I count number of pulses and worked that out into L/m.
thanks for the great news. In facts I never used esp8266. Can you explain a bit more? what is the “bill of material”?
thanks for your support, much appreciated
Andrea
Hi folks,
still I dind’t find a solution. Unfortunately the FortrezZ device is out of stock.
Any other clue?
thanks
Andrea
Maybe this one is also OK for you?
Volumenmessteil
I own one since one 1 1/2 years, 20 signals/liter. There are also other available (actual 10 and 100).
The seller is very friendly and for me he program a extra chjip with 20 signals / liter
I’m satisfied!
Hello, how did you manage the voltage with this sensor (5v mini) and esp8266 (3.3v) ?
Thank you.
Aymeric
