In the documentation for the binding in the Adding New Device Types section, it says
You can however load your own device_types.xml by referencing it in the network config parameters:
but I don’t see where the network config parameters are specified. Is it in a file or accessed via the UI? Both? Either? How?
I tried adding my own file, /usr/local/openhab/insteon/ezrain_device.xml, and adding it to the code of the hub so it looks like this:
UID: insteon:network:local
label: Insteon PLM or Hub
thingTypeUID: insteon:network
configuration:
additionalDevices: /usr/local/openhab/insteon/ezrain_device.xml
port: /hub2/Hexham24:bHNxxRo4@192.168.2.20:25105
devicePollIntervalSeconds: 1000
but nothing changed. It still doesn’t know about the productId I created.
