experimenting with my first custom widget set I struggle on a behaviour, I can’t understand right know. Through a combination of widgets I pass a JSON object as configuration for a template I would like to reuse on a few other widgets. Among other things this config contains a description to show different icons on states of a given items.
At first this seems to work like a charm, but every time I toggle the state of one of the three items in this configuration, the list seems to be reduce by one entry and thereby the icons are reduced too.
First “ON” command:
Second “ON” command:
Third “ON” command:
Maybe someone could see something I miss at the moment? Below is my used code and configuration.
uid: card_template
tags: []
props:
parameters:
- label: Header
required: false
type: TEXT
groupName: cardConfig
- description: Top-left corner icon
label: Icon
required: true
type: TEXT
- context: page
label: Page to show as a popup
required: false
type: TEXT
- context: item
description: Humidity item
label: Humidity item
required: false
type: TEXT
- label: States
required: false
type: TEXT
groupName: statusConfig
- context: widget
label: Test
required: false
type: TEXT
groupName: cwidget
- label: Content widget data
required: false
type: TEXT
groupName: cwidget
- label: Accent color
required: true
type: TEXT
parameterGroups:
- name: cardConfig
description: Card configuration
- name: cardAction
context: action
label: Action
description: Choose your recomended action
- name: statusConfig
description: Status section configuration
- name: cwidget
description: Content Widget
timestamp: Aug 18, 2024, 8:58:48 AM
component: oh-link
style:
--hf-accent-color: =(props.acolor || "var(--f7-theme-color)")
margin: 10px
border-radius: 20px
background-color: white
border: 6px solid var(--hf-accent-color)
box-shadow: rgba(50, 50, 93, 0.25) 0px 10px 16px -4px, rgba(0, 0, 0, 0.3) 0px 7px 11px -7px, inset rgba(50, 50, 93, 0.25) 0px 6px 12px -2px, inset rgba(0, 0, 0, 0.3) 0px 3px 7px -3px
margin-top: 10px
display: grid
grid-template: >
"icon header status" "values values status"
grid-template-columns: 70px calc(100% - 144px) 34px
grid-template-rows: 70px calc(100% - 70px)
column-gap: 20px
white-space: nowrap
opacity: 1 !important
action: popup
actionModal: =props.cardPopupPage
slots:
default:
- component: div
style:
width: 70px
height: 70px
background-color: var(--hf-accent-color)
border: 4px
border-bottom-right-radius: 20px
border-top-left-radius: 13px
grid-area: icon
slots:
default:
- component: div
style:
position: absolute
background-color: transparent
width: 20px
height: 20px
margin-top: 0px
margin-left: 70px
border-top-left-radius: 16px
box-shadow: -5px -5px 0px 0px var(--hf-accent-color)
- component: div
style:
position: absolute
width: 20px
height: 20px
margin-top: 70px
margin-left: 0px
- component: oh-button
style:
width: 52px
height: 52px
margin: 6px
border-radius: 16px
display: grid
align-items: center
justify-content: center
disabled: =(undefined === props.card_actionItem)
actionPropsParameterGroup: cardAction
slots:
default:
- component: oh-icon
icon: =props.cardIcon || ''
style:
height: 34px
width: 34px
- component: div
style:
grid-area: status
position: relative
color: white
height: 100%
slots:
default:
- component: div
style:
margin-top: 16px
margin-bottom: 16px
margin-left: 6px
display: flex
flex-direction: column
justify-content: space-evenly
gap: 16px
slots:
default:
- component: oh-repeater
for: listitem
fragment: true
sourceType: array
in: =JSON.parse(props.stateData)
slots:
default:
icon: =loop.listitem.states.find((e) => e.state === items[loop.listitem.item].state).icon
style:
height: 28px
width: 100%
visible: =((0 < loop.listitem.states.length) && (items[loop.listitem.item].state) && (undefined !== loop.listitem.states.find((e) => e.state === items[loop.listitem.item].state)))
- component: div
style:
height: 28px
width: 100%
visible: =((0 == loop.listitem.states.length) || (!items[loop.listitem.item].state) || (undefined === loop.listitem.states.find((e) => e.state === items[loop.listitem.item].state)))
- component: div
style:
position: absolute
width: 20px
height: 20px
top: 0px
left: -20px
border-top-right-radius: 16px
box-shadow: 5px -5px 0px 0px var(--hf-accent-color)
- component: div
style:
position: absolute
width: 20px
height: 20px
bottom: 0px
left: -20px
border-bottom-right-radius: 15px
box-shadow: 5px 5px 0px 0px var(--hf-accent-color)
- component: Label
style:
grid-area: header
width: 100%
font-weight: bold
font-size: 24px
text-align: left
vertical-align: middle
line-height: 70px
text: =props.cardLabel || ""
- component: =props.contentWidget
style:
grid-area: values
margin-bottom: 20px
contentData: =props.contentData
uid: card_room
tags: []
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
label: Prop 1
required: true
type: TEXT
- context: page
required: false
type: TEXT
- context: item
description: Toggle item
label: Item to toggle on icon click
required: false
type: TEXT
- context: item
description: Temprature item
label: Temperature item
required: false
type: TEXT
- context: item
description: Brightness item
label: Brightness item
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
description: Light status item
label: Light status item
required: false
type: TEXT
- context: item
description: Security status item
label: Security status item
required: false
type: TEXT
- context: item
description: Occupancy status item
label: Occupancy status item
required: false
type: TEXT
parameterGroups: []
timestamp: Aug 18, 2024, 9:07:29 AM
component: widget:card_template
cardLabel: =props.cardLabel
cardIcon: =props.cardIcon
cardPopupPage: =props.cardPopupPage
card_action: toggle
card_actionCommand: ON
card_actionCommandAlt: OFF
card_actionItem: =props.actionItem
contentWidget: widget:hf_value_row
contentData: ='[{"label":"Temperatur","item":"'+props.tempItem+'"},{"label":"Helligkeit","item":"'+props.brightItem+'"},{"label":"Luftfeuchtigkeit","item":"'+props.humItem+'"}]'
stateData: ='[{"item":"'+props.lightItem+'","states":[{"state":"ON", "icon":"iconify:mdi:lightbulb-on"}]},{"item":"'+props.securityItem+'", "states":[{"state":"ON", "icon":"iconify:mdi:shield-unlocked"}]},{"item":"'+props.occupancyItem+'", "states":[{"state":"ON", "icon":"iconify:mdi:person-circle"}]}]'
uid: hf_value_row
tags: []
props:
parameters:
- label: Values
required: false
type: TEXT
parameterGroups: []
timestamp: Aug 15, 2024, 1:58:48 PM
component: div
style:
grid-area: values
display: flex
flex-direction: row
margin: 10px 0px 16px 16px
gap: 10px
flex-wrap: wrap
slots:
default:
for: listitem
sourceType: array
fragment: true
in: =JSON.parse(props.contentData)
slots:
default:
- component: div
style:
color: props.textColor || var(--hf-accent-color)
display: flex
height: 46px
slots:
default:
- component: Label
text: =loop.listitem.label
style:
font-weight: bold
text-align: center
font-size: 14px
- component: Label
style:
padding-top: 4px
text-align: center
font-size: 14px
text: "=('-' === @loop.listitem.item ? '' : @loop.listitem.item)"
Configuration used for testing:
- component: widget:card_room
cardIcon: iconify:mdi:face-male
cardLabel: Zimmer Markus
lightItem: DeckenlampeMarkus
securityItem: DeckenlampeMarkus
occupancyItem: DeckenlampeMarkus
cardPopupPage: page:pageMarkus
card_action: toggle
card_actionItem: DeckenlampeMarkus
