Hi everyone,
I am migrating from Vera to OpenHAB and i am using the Homeseer Zwave stick.
So far everything is working great… moved switches, plugs for Zwave and even set schedules.
I am running into a snag with these Garage Door Controllers. They gave me an issue on Vera but eventually worked.
I am getting the device to include and iam getting the 2 expected channels as per the documentation. However i cant get it to securely include.as the detail on the device says zwave secure false.
I put it in low power include mode and even forced all devices to include securely. The zwave stick and laptop were 2 feet from the device.
Im running OpenHAB 3 with the v3 plugin of the Zwave binding. This is running on Windows 10.
I have set the variable to 255 to see if i can open the door… but no luck. The status always reports as NULL, but when i set it to 255 it says OPEN but nothing happens on the door. No alarm,flashing lights, or movement.
- zwave_class_basic
BASIC_TYPE_ROUTING_SLAVE
- zwave_class_generic
GENERIC_TYPE_ENTRY_CONTROL
zwave_neighbours
zwave_frequent
false
- modelId
NGD00Z-4
- zwave_version
0.0
- zwave_listening
true
- manufacturerId
014F
- manufacturerRef
4744:3030,4744:3032,4744:3530
- dbReference
11
- zwave_deviceid
12336
- zwave_nodeid
27
- vendor
Linear Corp
- defaultAssociations
1
- zwave_routing
true
- zwave_beaming
true
*** zwave_secure**
false
- zwave_class_specific
SPECIFIC_TYPE_SECURE_BARRIER_ADDON
- zwave_manufacturer
335
- zwave_devicetype
18244
