LswLogger Binding [Sofar/Omnik/IE wifi/eth stick for SolarmanPV]
Hi Piotr,
it seems it is the same, just the following items are provided:
Ambient temperature,
Module temperature,
Online,
Operating state,
Radiator temperature,
I will check tomorrow when sunrise and let you know if anything else changed.
BTW I am using 0.5.0 ver now.
P.S.: I switched to HA where everything works, but can test this one if needed later as well.
You can check logs, the essential items are not updated:
2024-05-24 09:18:35.450 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:18:35.771 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:18:35.961 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:18:36.171 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:18:36.400 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:05.454 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:05.725 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:05.913 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:06.113 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:06.344 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:23.024 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:25.714 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:25.714 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:19:25.714 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 53 °C
2024-05-24 09:19:25.715 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:19:25.715 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 48 °C
2024-05-24 09:19:25.715 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ changed from 47 °C to 48 °C
2024-05-24 09:19:25.715 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:19:25.715 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:19:25.715 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:19:25.716 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:19:25.716 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 51 °C
2024-05-24 09:19:25.716 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ changed from 50 °C to 51 °C
2024-05-24 09:19:25.716 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to 0 °C
2024-05-24 09:19:25.717 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ changed from -10607 °C to 0 °C
2024-05-24 09:19:25.717 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to -26362 °C
2024-05-24 09:19:25.717 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from 9237 °C to -26362 °C
2024-05-24 09:19:35.455 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:35.455 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:19:35.456 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 53 °C
2024-05-24 09:19:35.456 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:19:35.457 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 48 °C
2024-05-24 09:19:35.457 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:19:35.458 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:19:35.459 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:19:35.460 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:19:35.460 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 51 °C
2024-05-24 09:19:35.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to 15822 °C
2024-05-24 09:19:35.461 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ changed from 0 °C to 15822 °C
2024-05-24 09:19:35.462 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to 18965 °C
2024-05-24 09:19:35.462 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from -26362 °C to 18965 °C
2024-05-24 09:19:35.714 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:35.906 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:36.095 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:19:36.316 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:05.457 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:05.458 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:20:05.459 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 53 °C
2024-05-24 09:20:05.460 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:20:05.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 48 °C
2024-05-24 09:20:05.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:20:05.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:20:05.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:20:05.462 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:20:05.463 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 51 °C
2024-05-24 09:20:05.463 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to 15822 °C
2024-05-24 09:20:05.464 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to -28395 °C
2024-05-24 09:20:05.464 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from 18965 °C to -28395 °C
2024-05-24 09:20:05.726 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:05.970 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:06.158 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:06.367 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:35.469 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:35.470 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:20:35.471 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 53 °C
2024-05-24 09:20:35.472 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:20:35.472 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 48 °C
2024-05-24 09:20:35.474 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:20:35.475 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:20:35.476 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:20:35.476 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:20:35.477 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 51 °C
2024-05-24 09:20:35.477 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to 15822 °C
2024-05-24 09:20:35.478 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to -10475 °C
2024-05-24 09:20:35.478 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from -28395 °C to -10475 °C
2024-05-24 09:20:35.739 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:35.929 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:36.109 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:20:36.409 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:05.446 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:05.447 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:21:05.448 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 53 °C
2024-05-24 09:21:05.448 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:21:05.449 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 48 °C
2024-05-24 09:21:05.450 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:21:05.451 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:21:05.451 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:21:05.451 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:21:05.452 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 51 °C
2024-05-24 09:21:05.452 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to 15822 °C
2024-05-24 09:21:05.452 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to 7445 °C
2024-05-24 09:21:05.452 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from -10475 °C to 7445 °C
2024-05-24 09:21:05.715 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:05.905 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:06.095 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:06.345 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:23.089 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:27.591 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:35.457 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:35.726 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:35.916 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:36.097 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:21:36.326 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:08.832 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:09.104 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:09.283 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:09.494 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:09.723 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:35.453 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:35.712 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:35.903 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:36.103 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:22:36.332 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:05.459 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:05.718 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:05.909 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:06.098 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:06.329 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:23.099 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:29.207 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:35.527 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:35.797 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:35.986 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:36.176 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:23:36.456 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:05.462 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:05.732 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:05.922 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:06.102 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:06.392 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:35.462 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:35.732 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:35.913 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:36.103 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:24:36.333 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:05.466 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:05.724 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:05.914 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:06.105 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:06.335 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:23.158 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:25.748 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:25.749 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 54 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ changed from 53 °C to 54 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 49 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ changed from 48 °C to 49 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:25:25.750 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 52 °C
2024-05-24 09:25:25.751 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ changed from 51 °C to 52 °C
2024-05-24 09:25:25.751 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to 0 °C
2024-05-24 09:25:25.751 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ changed from 15822 °C to 0 °C
2024-05-24 09:25:25.751 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to -21117 °C
2024-05-24 09:25:25.751 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from 7445 °C to -21117 °C
2024-05-24 09:25:35.456 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:35.456 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:25:35.460 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 54 °C
2024-05-24 09:25:35.460 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:25:35.460 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 49 °C
2024-05-24 09:25:35.460 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:25:35.460 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:25:35.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:25:35.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:25:35.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 52 °C
2024-05-24 09:25:35.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to -29059 °C
2024-05-24 09:25:35.461 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ changed from 0 °C to -29059 °C
2024-05-24 09:25:35.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to -24811 °C
2024-05-24 09:25:35.461 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from -21117 °C to -24811 °C
2024-05-24 09:25:35.755 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:35.946 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:36.156 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:25:36.375 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:05.551 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:05.551 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:26:05.552 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 54 °C
2024-05-24 09:26:05.552 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:26:05.552 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 49 °C
2024-05-24 09:26:05.553 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:26:05.553 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:26:05.553 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:26:05.553 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:26:05.553 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 52 °C
2024-05-24 09:26:05.553 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to -29059 °C
2024-05-24 09:26:05.553 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to -6379 °C
2024-05-24 09:26:05.554 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from -24811 °C to -6379 °C
2024-05-24 09:26:05.932 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:06.113 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:06.303 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:06.602 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:42.246 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:42.246 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:26:42.248 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 54 °C
2024-05-24 09:26:42.249 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:26:42.249 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 49 °C
2024-05-24 09:26:42.250 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:26:42.250 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:26:42.250 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:26:42.250 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:26:42.250 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 52 °C
2024-05-24 09:26:42.250 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to -29059 °C
2024-05-24 09:26:42.250 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to 14869 °C
2024-05-24 09:26:42.251 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from -6379 °C to 14869 °C
2024-05-24 09:26:42.517 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:42.705 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:42.885 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:26:43.176 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:05.520 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:05.520 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Operating_state’ updated to grid-connected
2024-05-24 09:27:05.522 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_1’ updated to 54 °C
2024-05-24 09:27:05.522 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Ambient_temperature_2’ updated to 0 °C
2024-05-24 09:27:05.523 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_1’ updated to 49 °C
2024-05-24 09:27:05.525 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_3’ updated to 0 °C
2024-05-24 09:27:05.525 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_4’ updated to 0 °C
2024-05-24 09:27:05.526 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_5’ updated to 0 °C
2024-05-24 09:27:05.526 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Radiator_temperature_6’ updated to 0 °C
2024-05-24 09:27:05.527 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_1’ updated to 52 °C
2024-05-24 09:27:05.527 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_2’ updated to -29059 °C
2024-05-24 09:27:05.527 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ updated to 29205 °C
2024-05-24 09:27:05.527 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘G3_Hyd_beta_Module_temperature_3’ changed from 14869 °C to 29205 °C
2024-05-24 09:27:05.789 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:05.979 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:06.169 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:06.472 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:23.231 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:27.601 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:35.471 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:35.740 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:35.931 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:36.121 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
2024-05-24 09:27:36.390 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘G3_Hyd_beta_Online’ updated to ON
Hey folks, I am completely new to this topic and I wondered if you can help out as I am trying to get the data from my fresh installed Sofar Solar HYD 8-KTL Inverter. I already read a lot of info on supported and non supported LSW3 Logger. I am running a logger with Serial 239**** Version number LSW3_15_270A_1.68. I connected it via the binding and I do receive the basic data but for all Power related Data I only see “null”. is there any way I can access the data?
Thomas
@Piotr_Bojko I have been using the binding from OpenHAB distribution for a while and it was fine, after one of updates, it stopped working overnight. Disabling/enabling helps to connect to the inverter and the binding works ok until the inverted goes offline in the evening, the binding never reconnects when in the morning the inverter goes online again. It used to reconnects. In the settings I have 10 retries and 2160 as maxOfflineTime. Could you please take a look how to fix it? Thanks.
