Thanks for the comment, would you have a suggestion for a good topic title? What are you exactly missing? It contains manufacturer, the hardware type, the problem occuring. Happy to add something.
Regarding #10, I’ll add some environment information, even when I’m not sure what the CPU or RAM is relevant for this topic. But I respect the board rules.
If you still could add a hint how to debug a temperature sensor, that would be highly appreciated.
If the temp is consistently 5 degrees off then apply a temp offset of 5 degrees. You may can do this via PaperUI (click the more button to see all options) or use a rule with a proxy item to display the corrected temp.
