Luton Caseta switch items receiving commands out of nowhere after last OH update
Dear community,
Happy New Year everybody!
I’ve been running a stable 5.0 OH system on Ubuntu, no issues. Today I updated to 5.1 and Lutron switches are going insane. Somehow OH generates commands out of thin air, flooding the system and actually turning lights on and off.
This is what I see in the log (repeating into infinity):
2026-01-02 12:49:32.697 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Laundry_Light' received command OFF (source: org.openhab.core.thing$lutron:switch:caseta:laundry:switchstatus)
2026-01-02 12:49:32.698 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Laundry_Light' predicted to become OFF
2026-01-02 12:49:32.700 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Laundry_Light' updated to OFF
2026-01-02 12:49:32.748 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Laundry_Light' received command OFF (source: org.openhab.core.thing$lutron:switch:caseta:laundry:switchstatus)
If I go and turn the switch on manually, it turns back off!
There is not a single line in the rules that would use or modify this switch.
The switch is defined like this:
// luton.things
Bridge lutron:ipbridge:caseta "Lutron IP Access Point" @ "Equipment" [ ipAddress=IPADDRESSOFLUTRON] {
Thing switch laundry "Laundry" @ "Basement" [ integrationId=9 ]
// lutron.items
Switch Laundry_Light "Laundry Light" (gBasement_Lights) ["Lighting"] {channel="lutron:switch:caseta:laundry:switchstatus"}
Update: the problem is only related to switches, other Lutron devices like dimmers, picos, and shades work fine. Debug messages from the Lutron binding are not super-informative, it just shows a flood of messages being sent:
2026-01-02 12:58:07.401 [DEBUG] [utron.internal.handler.SwitchHandler] - Initializing Switch handler for integration ID 9
2026-01-02 12:58:07.402 [DEBUG] [utron.internal.handler.SwitchHandler] - Initializing device state for Switch 9
2026-01-02 12:58:07.402 [DEBUG] [ron.internal.handler.IPBridgeHandler] - Sending command ?OUTPUT,9,1
2026-01-02 12:58:07.411 [DEBUG] [ron.internal.handler.IPBridgeHandler] - Received message GNET> ~OUTPUT,9,1,0.00
2026-01-02 12:58:07.414 [DEBUG] [ron.internal.handler.IPBridgeHandler] - Sending command #OUTPUT,9,1,0
2026-01-02 12:58:07.475 [DEBUG] [ron.internal.handler.IPBridgeHandler] - Received message GNET> GNET> ~OUTPUT,9,1,0.00
2026-01-02 12:58:07.478 [DEBUG] [ron.internal.handler.IPBridgeHandler] - Sending command #OUTPUT,9,1,0
2026-01-02 12:58:07.499 [DEBUG] [ron.internal.handler.IPBridgeHandler] - Received message ~OUTPUT,9,1,0.00
2026-01-02 12:58:07.502 [DEBUG] [ron.internal.handler.IPBridgeHandler] - Sending command #OUTPUT,9,1,0
2026-01-02 12:58:07.548 [DEBUG] [ron.internal.handler.IPBridgeHandler] - Received message GNET> ~OUTPUT,9,1,0.00
Please help!
Thanks to the new feature in OH 5.1 we can see where these consoles are coming from.
The command’s are coming from the binding itself. It seems like it’s reflecting the stateUpdate back to the Item as a command. But it shouldn’t do that and I’m not sure what you can do about it except filling an issue.
Updated, I filed an issue: [lutron] Caseta switch items receiving a flood of repeating commands out of nowhere after update to OH 5.1 · Issue #19952 · openhab/openhab-addons · GitHub
